Home » Archived » Eclipse Process Manager (Stardust) » Other supported Java EE server(s) for Stardust ?
Other supported Java EE server(s) for Stardust ? [message #1695854] Tue, 19 May 2015 15:38 Go to next message
Hi Stardust team
May I inquire if Stardust will be supported on other open-source Java EE servers such
as GlassFish, TomEE and/or WildFly ( new JBoss) in future releases ?
Supported application servers according to release notes for Stardust 2.1.1 are:
IBM WebSphere 7, 8 (8.0.0.5 or later)
Oracle WebLogic 10.3.3, 10.3.6, 12.1.2 (12c)
JBoss 7.1, EAP 6.2
Jakarta Tomcat 7 (as servlet container)
Gudrun
[Updated on: Tue, 19 May 2015 15:39] by Moderator
Re: Other supported Java EE server(s) for Stardust ? [message #1695895 is a reply to message #1695854] Wed, 20 May 2015 03:46 Go to previous message
Gudrun,
So far there was little to no demand for these platforms and hence we currently have no plans to add official support for these. However, Stardust is standard compliant so chances are good that you may be able to run it on additional platforms, especially a Spring deployment. In many cases only minor tweaks to the class loading configuration are required (because other platforms may include conflicting libraries or library versions). I would for instance expect TomEE to be compatible with Tomcat. Jetty has also been used with Stardust.
Commercial customers can request platform support.
Best regards
Rob
Previous Topic:Deploying Workflow Model Using Console Command
Next Topic:MysqlXAException: No operations allowed after connection closed
Current Time: Sat Jul 19 09:28:07 EDT 2025
Powered by FUDForum. Page generated in 0.03848 seconds
