Home » Eclipse Projects » Sirius » Label expression with condition
Label expression with condition [message #1695825] Tue, 19 May 2015 10:30 Go to next message
In a column, I would like to change the column label according to the eobject features: if there is a string, I want to show something, otherwise, show a generic label. So, I was looking for putting a "if" condition in the label expression. Unfortunately, my expression is not interpreted and my code is pasted in the column.
The condition I put is the following:
[ if (self.goalReference->isEmpty()) ]
no reference
[else]
[self.goalReference.name]
[/if]
This condition/code works using the interpreter. But when I put it in the coilumn expression, it does not work
Any idea how to do that?
Thanks.
Re: Label expression with condition [message #1695842 is a reply to message #1695825] Tue, 19 May 2015 13:19 Go to previous messageGo to next message
It seems weird that this expression works in the interpreter as an
acceleo expression should be surrounded by [ /]. Anyway, Acceleo
provides the service "if" and should be used in a single expression as
follows:
[if(self.goalReference->isEmpty()) then '' else self.goalReference.name
endif/]
Note that if goalReference is a multivalued reference (as you use the
operation ->isEmpty) "self.goalReference.name" will return the
concatenation of the name of each referenced elements.
Steve
Le 19/05/2015 16:30, Julien Delange a écrit :
> Hello,
> no reference
> [else]
> [/if]
> Thanks.
Steve Monnier - Obeo
Need professional services for Sirius?
Re: Label expression with condition [message #1695844 is a reply to message #1695842] Tue, 19 May 2015 13:39 Go to previous messageGo to next message
Hi Steve,
I tried the solution but it does not work and it returns nothing - maybe this is because I am using the nightly build? is there any update on the acceleo language that would explain why the first solution worked first and your suggestion does not work, either in the interpreter or in the label expression?
Re: Label expression with condition [message #1695898 is a reply to message #1695844] Wed, 20 May 2015 03:56 Go to previous messageGo to next message
I do not think that this is caused by the version being a nightly build
(but I have been wrong before). The Acceleo language is pretty stable
and the nightly build should not be that different from an official
release. Why do you use a nightly build instead of a stable release?
Anyway, can you describe a little bit how is made your metamodel to work
this out? Is "goalReference" a multivalued reference? What is its parent
Metaclass? What is the type of this reference.
Steve
Le 19/05/2015 19:39, Julien Delange a écrit :
> Hi Steve,
> label expression?
Re: Label expression with condition [message #1705030 is a reply to message #1695898] Tue, 11 August 2015 10:02 Go to previous messageGo to next message
I have same problem. I set label expression to 'feature:isIdentifier' and I get either 'false' or 'true' string. That's right.
But I see nothing, when I set label expression to
[if (self.isIdentifier) then 'qwe' else 'asd' endif/]
Re: Label expression with condition [message #1705042 is a reply to message #1705030] Tue, 11 August 2015 11:22 Go to previous messageGo to next message
Hi Denis
Could try [(if (self.isIdentifier) then 'qwe' else 'asd' endif)/] ?
Note the () around the if .. endif: this force Acceleo to see it as an
OCL if.
This might indicate an issue in the Sirius Acceleo bridge.
Maxime - Obeo
Re: Label expression with condition [message #1705094 is a reply to message #1705042] Wed, 12 August 2015 02:29 Go to previous messageGo to next message
It doesn't help Sad Here is a test project:
https://github.com/AresEkb/anchor
My odesign file:
https://github.com/AresEkb/anchor/blob/master/anchor.design/description/anchor.odesign
And test model:
https://github.com/AresEkb/anchor/tree/master/anchor.tests/model
Even ['qwe'/] returns nothing...
Re: Label expression with condition [message #1705368 is a reply to message #1705094] Fri, 14 August 2015 04:12 Go to previous messageGo to next message
When I set "Label Expression" to [self.toString()/] I get the following exception:
STATUS
pluginId            org.eclipse.sirius.common.acceleo.mtl
pluginVersion       3.0.0.201506090807
code                0
severity            4
message             Argument types mismatch for module element dynamicModuleQuery6.
fingerprint         7bec1f74
Exception:org.eclipse.acceleo.engine.AcceleoEvaluationException: Argument types mismatch for module element dynamicModuleQuery6.
	 at org.eclipse.acceleo.engine.generation.AcceleoEngine.doEvaluate(AcceleoEngine.java:401)
	 at org.eclipse.acceleo.engine.generation.AcceleoEngine.evaluate(AcceleoEngine.java:203)
	 at org.eclipse.acceleo.engine.service.AcceleoEvaluationTask.evaluateQuery(AcceleoEvaluationTask.java:122)
	 at org.eclipse.acceleo.engine.service.AcceleoEvaluationTask.call(AcceleoEvaluationTask.java:291)
	 at org.eclipse.sirius.common.acceleo.mtl.business.internal.interpreter.DynamicAcceleoModule.evaluate(DynamicAcceleoModule.java:536)
	 at org.eclipse.sirius.common.acceleo.mtl.business.internal.interpreter.AcceleoMTLInterpreter.internalEvaluate(AcceleoMTLInterpreter.java:1125)
	 at org.eclipse.sirius.common.acceleo.mtl.business.internal.interpreter.AcceleoMTLInterpreter.evaluateString(AcceleoMTLInterpreter.java:679)
	 at org.eclipse.sirius.tools.internal.interpreter.ODesignGenericInterpreter.evaluateString(ODesignGenericInterpreter.java:161)
	 at org.eclipse.sirius.diagram.business.internal.metamodel.helper.DiagramElementMappingHelper.computeLabel(DiagramElementMappingHelper.java:114)
	 at org.eclipse.sirius.diagram.business.internal.experimental.sync.DDiagramElementSynchronizer.computeLabel(DDiagramElementSynchronizer.java:833)
	 at org.eclipse.sirius.diagram.business.internal.experimental.sync.DDiagramElementSynchronizer.refreshCenterLabel(DDiagramElementSynchronizer.java:482)
	 at org.eclipse.sirius.diagram.business.internal.experimental.sync.DDiagramElementSynchronizer.refresh(DDiagramElementSynchronizer.java:416)
	 at org.eclipse.sirius.diagram.business.internal.experimental.sync.DDiagramSynchronizer.createEdgeCandidates(DDiagramSynchronizer.java:1391)
	 at org.eclipse.sirius.diagram.business.internal.experimental.sync.DDiagramSynchronizer.refreshEdgeMapping(DDiagramSynchronizer.java:1312)
	 at org.eclipse.sirius.diagram.business.internal.experimental.sync.DDiagramSynchronizer.processEdgeMappingsRefresh(DDiagramSynchronizer.java:498)
	 at org.eclipse.sirius.diagram.business.internal.experimental.sync.DDiagramSynchronizer.refreshOperation(DDiagramSynchronizer.java:427)
	 at org.eclipse.sirius.diagram.business.internal.experimental.sync.DDiagramSynchronizer.refresh(DDiagramSynchronizer.java:352)
	 at org.eclipse.sirius.diagram.business.internal.sync.DDiagramSynchronizer.refresh(DDiagramSynchronizer.java:91)
	 at org.eclipse.sirius.diagram.business.internal.dialect.DiagramDialectServices.refresh(DiagramDialectServices.java:249)
	 at org.eclipse.sirius.business.internal.dialect.DialectManagerImpl.refresh(DialectManagerImpl.java:118)
	 at org.eclipse.sirius.business.api.dialect.command.RefreshRepresentationsCommand.doExecute(RefreshRepresentationsCommand.java:124)
	 at org.eclipse.emf.transaction.RecordingCommand.execute(RecordingCommand.java:135)
	 at org.eclipse.emf.workspace.EMFCommandOperation.doExecute(EMFCommandOperation.java:119)
	 at org.eclipse.emf.workspace.AbstractEMFOperation.execute(AbstractEMFOperation.java:150)
	 at org.eclipse.core.commands.operations.DefaultOperationHistory.execute(DefaultOperationHistory.java:516)
	 at org.eclipse.emf.workspace.impl.WorkspaceCommandStackImpl.doExecute(WorkspaceCommandStackImpl.java:208)
	 at org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute(AbstractTransactionalCommandStack.java:165)
	 at org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute(AbstractTransactionalCommandStack.java:219)
	 at org.eclipse.sirius.diagram.ui.tools.internal.editor.DDiagramEditorImpl.launchRefresh(DDiagramEditorImpl.java:1289)
	 at org.eclipse.sirius.diagram.ui.tools.internal.editor.DDiagramEditorImpl.access$2(DDiagramEditorImpl.java:1261)
	 at org.eclipse.sirius.diagram.ui.tools.internal.editor.DDiagramEditorImpl$2.run(DDiagramEditorImpl.java:636)
REPORT
comment
eclipseBuildId      4.5.0.I20150603-2000
eclipseProduct      org.eclipse.epp.package.modeling.product
javaRuntimeVersion  1.8.0_25-b18
osgiWs              win32
osgiOs              Windows7
osgiOsVersion       6.1.0
osgiArch            x86_64
logMessage          false
ignoreSimilar       false
BUNDLES
name                org.eclipse.acceleo.engine
version             3.6.0.201506080954
name                org.eclipse.core.commands
version             3.7.0.v20150422-0725
name                org.eclipse.core.jobs
version             3.7.0.v20150330-2103
name                org.eclipse.emf.transaction
version             1.9.0.201506010221
version             2.6.0.v20150601-0402
name                org.eclipse.emf.workspace
version             1.5.1.201506010221
name                org.eclipse.sirius
version             3.0.0.201506090807
name                org.eclipse.sirius.common.acceleo.mtl
name                org.eclipse.sirius.diagram
name                org.eclipse.sirius.diagram.ui
Re: Label expression with condition [message #1705369 is a reply to message #1705368] Fri, 14 August 2015 04:35 Go to previous messageGo to next message
I've got it. It seems that here is a simillar bug: https://www.eclipse.org/forums/index.php/t/781784/
When I run "Runntime Eclispe Application" from my workspace everithing works fine.
Re: Label expression with condition [message #1775002 is a reply to message #1695842] Mon, 23 October 2017 08:02 Go to previous messageGo to next message
Could someone help, How to use elseif statement
I tried using
aql:[if(self.Name='ABC') then ok1' elseif(self.Name='abc') then 'ok2' else 'wrong' endif/]
but it's not working
Re: Label expression with condition [message #1775059 is a reply to message #1775002] Tue, 24 October 2017 05:14 Go to previous message
You are mixing AQL (aql:) and Acceleo syntax ([/]).
See the documentation https://www.eclipse.org/sirius/doc/specifier/general/Writing_Queries.html to know more.
Previous Topic:Call Arrange All (Arrange Selection) when creating an edge
Next Topic:Change help expressions in Properties View in Sirius Diagram
Current Time: Sun Jul 20 10:05:14 EDT 2025
Powered by FUDForum. Page generated in 0.06289 seconds
