Home » Modeling » M2T (model-to-text transformation) » xpand to xtend2 type system migration(xpand to xtend2 type system migration)
xpand to xtend2 type system migration [message #1695180] Tue, 12 May 2015 09:48 Go to next message
I am trying to get comfort with xtend2 and we are migrating a project from xpand to xtend2.
In xpand, we have 'type system' expression as follows:
«DEFINE Include_H FOR AUTOSAR::EcucDefs::Com»
We would like to derieve the similar type-systems in xtend2 i.e. in .xtend templates. Could you please point me if already supported in xtend2 or should i need to write similar wrappers in xtend2?. Also, how easy i can do this. If the migration is required, any documentation is of great help.
Hari
Re: xpand to xtend2 type system migration [message #1695216 is a reply to message #1695180] Tue, 12 May 2015 13:55 Go to previous messageGo to next message
there is not reflective type system.
thus you need physical wrappers
are these wrappers for param defs or for param values?
if it is for param values:
artop can generate xtend wrapper classes as well) they can then be used by the generator.
the generator can be found here: https://www.artop.org/gitweb/?p=development/ecuc;a=tree;f=aal/examples;h=b67a74e48bd51cfdaeaaabb60d52135e7aa7b826;hb=HEAD
the generated code here: https://www.artop.org/gitweb/?p=development/ecuc;a=tree;f=aal/plugins/org.artop.ecuc.autosar421.accessors;h=769035652163d0abee9f6c6be5c17f5932e03db6;hb=HEAD
i dont know if it already ships them
you can then wrap ecucmoduleconfigvalues into one of it default occurrences
Re: xpand to xtend2 type system migration [message #1695286 is a reply to message #1695216] Wed, 13 May 2015 07:10 Go to previous messageGo to next message
Hi Christian,
Thanks for update and it's really a good pointer for me to start with.
Currently, I am struggling to run the plugins from the links provided by you due to dependency issues. Any simple steps to work with these plugins / resolve dependency without any compilation issues?
OR
How can i replicate the same setup at my place that the developers are having at artop? OR can i get any ready made setup to simple import these plugins and run?. I am sure Artext will not suffice the purpose.
Re: xpand to xtend2 type system migration [message #1695293 is a reply to message #1695286] Wed, 13 May 2015 07:33 Go to previous messageGo to next message
did you have a look if artop already contains these plugins? org.artop.ecuc.autosar421.accessors
if so you should be ablte to install them through eclipse update (p2)
(and add them to your target platform so that everybody gets it)
Re: xpand to xtend2 type system migration [message #1695296 is a reply to message #1695293] Wed, 13 May 2015 07:44 Go to previous messageGo to next message
I have verified all variants of artop, 'org.artop.ecuc.autosar421.accessors' is not part of any variant.
Re: xpand to xtend2 type system migration [message #1695298 is a reply to message #1695296] Wed, 13 May 2015 07:52 Go to previous messageGo to next message
sure?
and simly using the sources for that plugin does not work? what is the error message you get?
Re: xpand to xtend2 type system migration [message #1695299 is a reply to message #1695296] Wed, 13 May 2015 07:52 Go to previous messageGo to next message
P.S: maybe that is something you should directly ask to artop
Re: xpand to xtend2 type system migration [message #1695301 is a reply to message #1695299] Wed, 13 May 2015 08:00 Go to previous messageGo to next message
p.p.s: i just talked to the itemis france guys that maintain that thing: it is in artop 4.5 nightly only
Re: xpand to xtend2 type system migration [message #1695315 is a reply to message #1695299] Wed, 13 May 2015 09:05 Go to previous messageGo to next message
It will be the good option. to use this, 'org.artop.ecuc.autosar421.accessors' has dependency on 'org.artop.ecuc.gautosar.accessors.lib'.
and this lib plugin is missing IWrapper (import org.eclipse.sphinx.emf.util.IWrapper) interface. Which means, w.r.t. spinx installation, i have a version mis-match between the accessor plugins and the installation which i have locally.
As you suggested, i tried sending the mails and bouncing with following error message: Any help on which mail id i should send.
'sorry, no mailbox here by that name (#5.1.1) '
membership@artop.org (membership@artop.org)
development@artop.org (development@artop.org)
artext@artop.org (artext@artop.org)
Re: xpand to xtend2 type system migration [message #1695316 is a reply to message #1695315] Wed, 13 May 2015 09:07 Go to previous messageGo to next message
Oh! then i am wondering if i can use this. If so, how can i?. Please help me with a valid artop mail id.
Thank you so much for your help.
Re: xpand to xtend2 type system migration [message #1695317 is a reply to message #1695316] Wed, 13 May 2015 09:12 Go to previous messageGo to next message
Sorry i cannot help you with that. Ask the artop contact person in your company
Re: xpand to xtend2 type system migration [message #1695321 is a reply to message #1695317] Wed, 13 May 2015 09:21 Go to previous message
Ps the nightly can be found in the buildserver but i have n link for that
Previous Topic:[Acceleo] Difficulties with variables
Next Topic:UML2C where to start
Current Time: Sun Jul 20 05:35:13 EDT 2025
Powered by FUDForum. Page generated in 0.05683 seconds
