[Xcore] Adding new super class to all classes in an EMF model [message #1695173] |
Tue, 12 May 2015 09:26  |
currently I have a problem to find an easy way to modify an existing model.
We have different defined models based on EMF (Xcore).
Now a requirement is to add to all elements of a model attributes.
Therefore we already have defined an interface containing those.
Sample:
interface SampleA
contains resolving MyAttribute [] myAttribute
Goal is that all defined classes are having these myAttribute available, if possible without explicit extending it, as the model is very large and we have to touch a lot of elements.
First idea was to add the base class and its provider to the Genmodel annotation:
@GenModel(
... rootExtendsClass="package.myclass",
providerRootExtendsClass="package.myclassprovider)
Problem with that solution is that I'm able to see the entry in the editor, but I'm not able to use it. It's greyed out.
Is there something missing or another simple way existing to achieve such a constellation?
Fallback would be to add to all elements the extend SampleA...
Daniel
Re: [Xcore] Adding new super class to all classes in an EMF model [message #1695175 is a reply to message #1695173] |
Tue, 12 May 2015 09:38   |
Daniel,
Comments below.
On 12/05/2015 3:26 PM, Daniel K. wrote:
> model.
> Sample:
> interface SampleA
No, this is impossible.
> annotation:
> @GenModel(
Which editor? These things should be fully qualified names of classes,
but a root extends class must be a class like EObjectImpl without any
explicitly modeled features.
No, if you want modeled features they must be explicitly known in the
Ecore model itself and hence must be explicit in the Xcore model.
It's the only way.
> Regards
> Daniel
FUDForum. Page generated in 0.06022 seconds
