Home » Modeling » EMF » [Xcore] Adding new super class to all classes in an EMF model
[Xcore] Adding new super class to all classes in an EMF model [message #1695173] Tue, 12 May 2015 09:26 Go to next message
currently I have a problem to find an easy way to modify an existing model.
We have different defined models based on EMF (Xcore).
Now a requirement is to add to all elements of a model attributes.
Therefore we already have defined an interface containing those.
Sample:
interface SampleA
contains resolving MyAttribute [] myAttribute
Goal is that all defined classes are having these myAttribute available, if possible without explicit extending it, as the model is very large and we have to touch a lot of elements.
First idea was to add the base class and its provider to the Genmodel annotation:
@GenModel(
... rootExtendsClass="package.myclass",
providerRootExtendsClass="package.myclassprovider)
Problem with that solution is that I'm able to see the entry in the editor, but I'm not able to use it. It's greyed out.
Is there something missing or another simple way existing to achieve such a constellation?
Fallback would be to add to all elements the extend SampleA...
Daniel
Re: [Xcore] Adding new super class to all classes in an EMF model [message #1695175 is a reply to message #1695173] Tue, 12 May 2015 09:38 Go to previous messageGo to next message
Daniel,
Comments below.
On 12/05/2015 3:26 PM, Daniel K. wrote:
> model.
> Sample:
> interface SampleA
No, this is impossible.
> annotation:
> @GenModel(
Which editor? These things should be fully qualified names of classes,
but a root extends class must be a class like EObjectImpl without any
explicitly modeled features.
No, if you want modeled features they must be explicitly known in the
Ecore model itself and hence must be explicit in the Xcore model.
It's the only way.
> Regards
> Daniel
Re: [Xcore] Adding new super class to all classes in an EMF model [message #1695181 is a reply to message #1695175] Tue, 12 May 2015 09:53 Go to previous messageGo to next message
the standard EMF Tree Editor.
But that answers my question that if we want to add modeled features we have to add it "manually".
Thanks for the fast reply.
Daniel
[Updated on: Wed, 13 May 2015 02:21] by Moderator
Re: [Xcore] Adding new super class to all classes in an EMF model [message #1695209 is a reply to message #1695181] Tue, 12 May 2015 12:07 Go to previous messageGo to next message
An Ecore-Model is an EMF-Model by itself you so you load the meta model,
modify it and save it back to disk.
Tom
On 12.05.15 15:53, Daniel K. wrote:
> have to add it "manualy".
> Regards
> Daniel
Re: [Xcore] Adding new super class to all classes in an EMF model [message #1695211 is a reply to message #1695209] Tue, 12 May 2015 12:10 Go to previous messageGo to next message
.... oh i missed the xcore. So you have only .xcore files?
Tom
> Tom
>> Hi,
>> Regards
>> Daniel
Re: [Xcore] Adding new super class to all classes in an EMF model [message #1695258 is a reply to message #1695211] Wed, 13 May 2015 02:21 Go to previous message
yes, we defined the model itself using xcore, which is our master source.
Previous Topic:Deadlock during EPackage initialization for cyclic package interdependencies
Next Topic:storing html values in xmi
Current Time: Sun Jul 20 08:20:05 EDT 2025
Powered by FUDForum. Page generated in 0.04387 seconds
