Home » Modeling » Papyrus » import an uml model into ecore file
import an uml model into ecore file [message #1694960] Sun, 10 May 2015 17:43 Go to next message
I created an uml model with papyrus and tried to import it into an emf generated model, but the ecore file generated does not have the associations Crying or Very Sad
i think there is something missing with the associations in the model explorer like a property that i should add to the classes.
I attached a screenshot of an uml exemple with the model explorer.
index.php/fa/21766/0/
  • Attachment: 4.png
    (Size: 13.16KB, Downloaded 942 times)
[Updated on: Tue, 12 May 2015 02:33] by Moderator
Re: import an uml model into ecore file [message #1695030 is a reply to message #1694960] Mon, 11 May 2015 09:26 Go to previous messageGo to next message
Indeed, the image that you attach shows an association that owns both
of its ends. Because Ecore does not have an explicit model of
associations (EReferences may indicate their opposites), you need the
classes at one or both ends of the association to own the corresponding
property.
The tool that you show in the screenshot is not Papyrus, so I don't
know how to help with that. But in Papyrus, the Properties view makes
it easy to change the ownership of an association end. Select the
association and you will find a pick-list for each end that lets you
choose the Association or the Classifier as the owner (of course, an
association is a classifier, but whatever).
HTH,
Christian
> associations :cry:
> <image>
Re: import an uml model into ecore file [message #1695031 is a reply to message #1695030] Mon, 11 May 2015 09:28 Go to previous messageGo to next message
Hmm, sorry, of course that's Papyrus. I just didn't recognize the
Windows UI ...
Christian
On 2015-05-11 13:26:55 +0000, Christian W. Damus said:
> property.
> HTH,
> Christian
>> associations :cry:
>> <image>
Re: import an uml model into ecore file [message #1695053 is a reply to message #1694960] Mon, 11 May 2015 11:43 Go to previous messageGo to next message
Selma Bns a écrit :
> I created an uml model with papyrus and tried to import it into an emf generated model, but the ecore file generated does not have the associations :cry:
Your classes should own the ends of the association.
- Select the association
- Open the Properties view
- Select the UML tab
- Locate the 'Member End' you want to change,
- Set 'Owner' to 'Classifier' on the end(s) you want to use in ECore.
Both end can be changed.
Hope this help,
Cedric
  • Attachment: memberEnd.png
    (Size: 12.94KB, Downloaded 179 times)
Re: import an uml model into ecore file [message #1695110 is a reply to message #1695053] Tue, 12 May 2015 02:54 Go to previous message
Thank you so much Very Happy this solution worked for me.
Previous Topic:newbee: How to locate an element in the model explorer(
Next Topic:Java Code Generator fails
Current Time: Sun Jul 20 11:09:19 EDT 2025
Powered by FUDForum. Page generated in 0.04764 seconds
