Home » Eclipse Projects » RCP Testing Tool » Issue with substitute-variables
Issue with substitute-variables [message #1694845] Fri, 08 May 2015 08:37 Go to next message
Hey there,
i have a problem with using the subsitute-variables command. I have build a script like the example on www.xored.com/2013/09/03/how-to-pass-a-value-to-a-test-during-its-execution/:
log [subsitute-variables "${system_property:propertyName}"]
On executing the script, i'll get the following error message: "Scriptlet SubsituteVariables not found at subsitute-variables". I've tested the versions 1.5.5 and 1.5.6.201505072316 Nightly.
Maybe you have ideas of what i made wrong?
Thanks for your help Smile
Re: Issue with substitute-variables [message #1694846 is a reply to message #1694845] Fri, 08 May 2015 08:51 Go to previous messageGo to next message
Hi Jan,
There is a typo in substitute-variables (missing "t" letter).
Yours sincerely,
Ulyana.
Re: Issue with substitute-variables [message #1694852 is a reply to message #1694846] Fri, 08 May 2015 09:14 Go to previous message
Hey Ulyana,
thank you for this realy fast answer. You saved a lot of my time Smile
Previous Topic:interaction with running script on AUT
Next Topic:Reading csv-file from workspace
Current Time: Sun Jul 20 05:53:49 EDT 2025
Powered by FUDForum. Page generated in 0.03385 seconds
