Home » Modeling » EMF » [XCore] Unable to create a data type of an array of EMF Ecore Classes (e.f. EStructuralFeature)(Xcore complaints on "type EStructuralFeaturesArray wraps EStructuralFeature[]")
[XCore] Unable to create a data type of an array of EMF Ecore Classes (e.f. EStructuralFeature) [message #1694179] Fri, 01 May 2015 11:53 Go to next message
I would like to model an operation with a parameter that is simple array of EStructuralFeature. But the following line raises an error
Error Raised:
"Couldn't resolve reference to JvmType 'EParameter'"
Is it possible to do that? My meta-model already contains simple reference to EStructuralFeature but the definition of this new Data Type does not seem to work.
Thanks Wink
Re: [XCore] Unable to create a data type of an array of EMF Ecore Classes (e.f. EStructuralFeature) [message #1694219 is a reply to message #1694179] Sat, 02 May 2015 09:10 Go to previous messageGo to next message
Regent,
Which version of Xcore are you using?
On 01/05/2015 5:53 PM, Regent LArcheveque wrote:
> Error Raised: "Couldn't resolve reference to JvmType 'EParameter'"
I can reproduce this with the Mars version, though the error is about
EStructuralFeature not EParameter. If I change it to be
org.eclipse.emf.ecore.EStructuralFeature[] then the error goes away, so
it seems yet another scoping problem.
It should be yes.
No, from a preliminary analysis, it seems to be a problem that an import
that can resolve to GenClassifier can't also be used to resolve to a
JvmType in the cached synthetic import section that's created... So
there's definitely something that needs to be fixed here. Please open a
bugzilla. This simple test case reproduces the problem:
package test
import org.eclipse.emf.ecore.EStructuralFeature
type Foo wraps EStructuralFeature
> Thanks ;)
Re: [XCore] Unable to create a data type of an array of EMF Ecore Classes (e.f. EStructuralFeature) [message #1694320 is a reply to message #1694219] Mon, 04 May 2015 08:49 Go to previous messageGo to next message
Regent,
I've opened https://bugs.eclipse.org/bugs/show_bug.cgi?id=466305 and
committed the fix. It will be in the M7 build.
On 02/05/2015 3:10 PM, Ed Merks wrote:
> Regent,
>> Hi,
> so it seems yet another scoping problem.
> It should be yes.
> import that can resolve to GenClassifier can't also be used to resolve
> to a JvmType in the cached synthetic import section that's created...
> So there's definitely something that needs to be fixed here. Please
> open a bugzilla. This simple test case reproduces the problem:
> package test
>> Thanks ;)
Re: [XCore] Unable to create a data type of an array of EMF Ecore Classes (e.f. EStructuralFeature) [message #1694335 is a reply to message #1694320] Mon, 04 May 2015 10:12 Go to previous message
Thanks Ed. For your info, I use XCore 1.2.2v20150202-0452.
Have a nice day Wink
Previous Topic:Help with Wiki page
Next Topic:[CDO] MARS Enhancements
Current Time: Sat Jul 19 21:53:36 EDT 2025
Powered by FUDForum. Page generated in 0.03362 seconds
