Home » Eclipse Projects » Equinox » Update site contents in dropins folder gets No repository found
Update site contents in dropins folder gets No repository found [message #1693871] Tue, 28 April 2015 22:17
To create an Eclipse bundle for our end users, I have been adding various items to the plugins folder in Luna SR2 (4.4.2). One plugin isn't installing.
I copied features/, plugins/ and site.xml of the AccuRev plugin to dropins/accurev/UpdateSite/. Starting Eclipse produced the following in .metadata/.log:
!ENTRY org.eclipse.equinox.p2.core 4 0 2015-04-28 14:35:09.164
!MESSAGE Provisioning exception
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: No repository found at file:/J:/landmark/dluna/eclipse442/dropins/accurev/.
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.fail(AbstractRepositoryManager.java:395)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:692)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:96)
Manually installing using an update site of dropins/accurev/UpdateSite/ worked fine.
Any ideas about how I can get this working in the dropins folder?
Previous Topic:Use Delta Pack through generate setup file create time error
Next Topic:Equinox, chose service implementation at runtime
Current Time: Sun Jul 20 16:45:53 EDT 2025
Powered by FUDForum. Page generated in 0.03808 seconds
