Home » Eclipse Projects » NatTable » Problem with adding FilterRowHeaderComposite to CompositeLayer
Problem with adding FilterRowHeaderComposite to CompositeLayer [message #1693807] |
Tue, 28 April 2015 08:57  |
When I add the FilterRowHeaderComposite to CompositeLayer , the filter text is being disabled on runtime
Test code is below
public Control createExampleControl(Composite parent) {
// create a new ConfigRegistry which will be needed for GlazedLists
// handling
ConfigRegistry configRegistry = new ConfigRegistry();
// property names of the Person class
String[] propertyNames = { "firstName", "lastName", "gender",
"married", "birthday", "address.street", "address.housenumber",
"address.postalCode", "address.city" };
// mapping from property to label, needed for column header labels
Map propertyToLabelMap = new HashMap();
propertyToLabelMap.put("firstName", "Firstname");
propertyToLabelMap.put("lastName", "Lastname");
propertyToLabelMap.put("gender", "Gender");
propertyToLabelMap.put("married", "Married");
propertyToLabelMap.put("birthday", "Birthday");
propertyToLabelMap.put("address.street", "Street");
propertyToLabelMap.put("address.housenumber", "Housenumber");
propertyToLabelMap.put("address.postalCode", "Postal Code");
propertyToLabelMap.put("address.city", "City");
IColumnPropertyAccessor columnPropertyAccessor = new ExtendedReflectiveColumnPropertyAccessor(
propertyNames);
BodyLayerStack bodyLayerStack = new BodyLayerStack(
PersonService.getPersonsWithAddress(50), columnPropertyAccessor);
// build the column header layer
IDataProvider columnHeaderDataProvider = new DefaultColumnHeaderDataProvider(
propertyNames, propertyToLabelMap);
DataLayer columnHeaderDataLayer = new DefaultColumnHeaderDataLayer(
columnHeaderDataProvider);
ILayer columnHeaderLayer = new ColumnHeaderLayer(columnHeaderDataLayer,
bodyLayerStack, bodyLayerStack.getSelectionLayer());
// Note: The column header layer is wrapped in a filter row composite.
// This plugs in the filter row functionality
FilterRowHeaderComposite filterRowHeaderLayer = new FilterRowHeaderComposite(
new DefaultGlazedListsFilterStrategy(
bodyLayerStack.getFilterList(), columnPropertyAccessor,
configRegistry), columnHeaderLayer,
columnHeaderDataLayer.getDataProvider(), configRegistry);
CompositeLayer compositeLayer = new CompositeLayer(1,2);
compositeLayer.setChildLayer(GridRegion.COLUMN_HEADER, filterRowHeaderLayer, 0, 0);
compositeLayer.setChildLayer(GridRegion.BODY, bodyLayerStack, 0, 1);
// turn the auto configuration off as we want to add our header menu
// configuration
NatTable natTable = new NatTable(parent, compositeLayer, false);
// as the autoconfiguration of the NatTable is turned off, we have to
// add the
// DefaultNatTableStyleConfiguration and the ConfigRegistry manually
natTable.setConfigRegistry(configRegistry);
natTable.addConfiguration(new DefaultNatTableStyleConfiguration());
// add filter row configuration
natTable.addConfiguration(new FilterRowConfiguration());
natTable.configure();
natTable.registerCommandHandler(new DisplayPersistenceDialogCommandHandler(
natTable));
return natTable;
What is the problem?
Can be used FilterRowHeaderComposite in CompositeLayer?
Re: Problem with adding FilterRowHeaderComposite to CompositeLayer [message #1693814 is a reply to message #1693813] |
Tue, 28 April 2015 09:25   |
Thaknk You for your responce I added row editable. But result is same. The code is below. (I think the problem is setChildLayer of CompositeLayer.)
// handling
propertyNames);
// configuration
// add the
natTable.addConfiguration(new AbstractRegistryConfiguration() {
public void configureRegistry(IConfigRegistry configRegistry) {
configRegistry.registerConfigAttribute(
EditConfigAttributes.CELL_EDITABLE_RULE,
IEditableRule.ALWAYS_EDITABLE,
DisplayMode.NORMAL,
GridRegion.FILTER_ROW
natTable));
return natTable;
Current Time: Sun Jul 20 12:39:02 EDT 2025
Powered by FUDForum. Page generated in 0.03877 seconds
