Home » Eclipse Projects » GEF » CompoundDirectedGraphLayout question
CompoundDirectedGraphLayout question [message #168961] Sun, 20 February 2005 22:08 Go to next message
Originally posted by: yabing.crimsonlogic.com
I need to layout a graph, which contains subgraphs. each subgraph is a
rectangle box containing some nodes. the subgraph is like a database
table. columns in the table are its nodes. and there are two types of
connection lines. one is between subgraphs, or between tables. the other
is between one node in one subgraph (one column in one table) and another
node in another subgraph (another column in another table). there is no
connection line within one subgraph or one table. in this case, can I use
CompoundDirectedGraphLayout to make a nice layout of the graph? if not, is
there any other way?
Thanks a lot!
Yabing
Re: CompoundDirectedGraphLayout question [message #169085 is a reply to message #168961] Mon, 21 February 2005 11:02 Go to previous messageGo to next message
Wouldn't the columns of a table be layed out vertically top-to-bottom?
"yabing chen" <yabing@crimsonlogic.com> escreveu na mensagem
news:cvbjak$jkb$1@www.eclipse.org...
> Thanks a lot!
> Yabing
Re: CompoundDirectedGraphLayout question [message #169356 is a reply to message #169085] Tue, 22 February 2005 20:46 Go to previous messageGo to next message
Thanks! got a reply finally.
yeah, the columns of a table is layed out vertically top-to-bottom, and
their location in the table shouldn't be changed in the layout. the
purpose of the layout is to change the location of all the tables to make
them and the connections between them and the connections between columns
presented nicely. can do it using CompoundDirectedGraphLayout?
Yabing
>> Hi,
>> Thanks a lot!
>> Yabing
Re: CompoundDirectedGraphLayout question [message #169450 is a reply to message #169356] Wed, 23 February 2005 10:23 Go to previous message
Probably so.
news:cvgn92$8pr$1@www.eclipse.org...
> Regards,
> Yabing
Previous Topic:WYSIWYG Text Editing
Next Topic:Filtering models
Current Time: Sat Jul 19 07:42:04 EDT 2025
Powered by FUDForum. Page generated in 0.07020 seconds
