Issues with moving elements between models [message #1693319] |
Thu, 23 April 2015 04:08  |
I've did some tests with a new model structure today, and a a part of this I also tried to move a package containing a block and a diagram to another model. Working with Papyrus Luna SR2.
An example:
The block 'Part AA' is in the package I want to move (OtherLib), and the part 'Safety PLC' is from another imported library containing common parts shared between all models.
First, in model A, I imported the target package (OtherLibExternal) from model B. Then I moved the package (OtherLib)containing the block(s), associations and a diagram I wanted to move. Closed the diagram above and reopened it, and got this:
Also when opening OtherLibExternal, the diagram was lost.
Shouldn't this work?
And to make things weird, I made the import the other way (model A into B) around one time, didn't work, remade the import (model B into A), and all of a sudden it worked! But after closing the model, it was back to the failed state again.
Cleared up the diagram by either deleting or hiding the parts not possible to show, made sure there was no references or import elements for OtherLibExternal (which not is totally empty), but still OtherLibExternal pops up in the ModelExplorer each time i open model A. The only way I could get rid of OtherLibExternal was to delete its model files.
So, am I trying something not supposed to be possible here? Or are there flaws in the mechanisms for moving parts of a model to another model?
Tomas
Re: Issues with moving elements between models [message #1693320 is a reply to message #1693319] |
Thu, 23 April 2015 04:19   |
Hi Tomas,
Moving an element from one resource to another is a refactoring operation, which is not always properly handled by Papyrus. Unlike simple changes, refactoring operations may cause inconsistencies in related models if they are not consistently saved during this operation.
We did some work on the Control Mode operation (Which is also a similar refactoring) to ensure consistency, but we didn't generalize that to elements moved from one model to another.
The workaround (To avoid the issue) would be to force a change in the Diagrams, to ensure that they are consistently saved. Otherwise, diagrams will be considered unmodified and will not be saved, causing this inconsistency.
The second workaround (To repair the model) would be to use the Refactor > Switch Library operation, but this is probably too much in that case, because it would update *all* references to a model to references to another model. In this case, you only want to update some of them (the broken ones), so that's probably not an option
So that's definitely a bug in Papyrus, and I don't think it has been reported yet
Camille
FUDForum. Page generated in 0.03867 seconds
