problems with viewByTitle in Mars [message #1692227] |
Tue, 14 April 2015 07:52  |
I started to port one of my projects to Mars, where SWTBot is used
extensively (https://www.eclipse.org/emf-parsley/).
The tests that use bot.viewByTitle fail, though the view is actually
visible when the test is run.
By debugging, it looks like the culprit is a change in
org.eclipse.ui.internal.WorkbenchPage.getViewReferences (which is used
in SWTBot by WorkbenchContentsFinder.findViewsInternal).
In Luna, the code of getViewReferences used to be
public IViewReference[] getViewReferences() {
MPerspective perspective = getCurrentPerspective();
if (perspective != null) {
List<MPlaceholder> placeholders = modelService.findElements(window, null,
MPlaceholder.class, null, EModelService.PRESENTATION);
List<IViewReference> visibleReferences = new ArrayList<IViewReference>();
for (ViewReference reference : viewReferences) {
for (MPlaceholder placeholder : placeholders) {
if (reference.getModel() == placeholder.getRef()
&& placeholder.isToBeRendered()) {
// only rendered placeholders are valid view references
visibleReferences.add(reference);
return visibleReferences.toArray(new
IViewReference[visibleReferences.size()]);
return new IViewReference[0];
In Mars, it became
return getViewReferences(false);
private IViewReference[] getViewReferences(boolean allPerspectives) {
int scope = allPerspectives ? WINDOW_SCOPE : EModelService.PRESENTATION;
MPlaceholder.class, null, scope);
and my views are not found anymore (again, my view is visible in the
current perspective)...
has anyone else experienced such problems when switching to Mars?
thanks in advance
Lorenzo
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
FUDForum. Page generated in 0.04102 seconds
