How to format lists with new Xtext formatter? [message #1692650] |
Fri, 17 April 2015 04:24  |
I am trying to format text for the following grammar snippet:
EventAction:
name=STRING
CallServerProcedureCommand:
'callServer' ('{'
('additionalActions' '{' additionalActions+=EventAction* '}')?
The final text should look something like:
callServer {
additionalActions {
"onSave"
"onLoad"
No matter what I try I do not get the increase/decrease stuff for the curly braces to work correctly. Mostly it looks like:
callServer qi.X332 {
additionalActions {
"onSave"
"onLoad"
I find all regions for the braces and apply increase/decrease indentation to them, but with no luck.
What am I missing?
Jan Rosczak
Re: How to format lists with new Xtext formatter? [message #1692658 is a reply to message #1692650] |
Fri, 17 April 2015 05:30   |
the problem is that you have the same keywords twice { }
the api for regionForKeyword cannot handle that.
it it missing a method
def ISemanticRegion regionForKeyword(EObject owner, Keyword keyword)
can you file a enhancement request for that?
additionally the eObjectTokens list should be available in the api as well => enhancement request for that
as a workaround
* generated by Xtext
package org.xtext.example.mydsl1.formatting2
import com.google.common.collect.ImmutableMap
import java.util.Map
import javax.inject.Inject
import org.eclipse.emf.ecore.EObject
import org.eclipse.xtext.AbstractElement
import org.eclipse.xtext.Keyword
import org.eclipse.xtext.formatting2.AbstractFormatter2
import org.eclipse.xtext.formatting2.IFormattableDocument
import org.eclipse.xtext.formatting2.regionaccess.ISemanticRegion
import org.eclipse.xtext.formatting2.regionaccess.ITextRegionAccess
import org.eclipse.xtext.formatting2.regionaccess.internal.AbstractEObjectTokens
import org.eclipse.xtext.formatting2.regionaccess.internal.NodeModelBasedRegionAccess
import org.xtext.example.mydsl1.myDsl.CallServerProcedureCommand
import org.xtext.example.mydsl1.services.MyDslGrammarAccess
import org.xtext.example.mydsl1.myDsl.EventAction
// import com.google.inject.Inject;
// import org.xtext.example.mydsl1.services.MyDslGrammarAccess
* This class contains custom formatting declarations.
* See https://www.eclipse.org/Xtext/documentation/303_runtime_concepts.html#formatting
* on how and when to use it.
* Also see {@link org.eclipse.xtext.xtext.XtextFormattingTokenSerializer} as an example
class MyDslFormatter extends AbstractFormatter2 {
@Inject
MyDslGrammarAccess ga
def dispatch void format(CallServerProcedureCommand p, extension IFormattableDocument doc) {
println("lala")
if (regionAccess instanceof MyDslNodeModelBasedRegionAccess) {
//p.regionForKeyword("{").append [
// setNewLines(1,1,1);
// increaseIndentation
p.regionForKeyword(ga.callServerProcedureCommandAccess.leftCurlyBracketKeyword_2_0, regionAccess).append [
setNewLines(1,1,1);
increaseIndentation
p.regionForKeyword(ga.callServerProcedureCommandAccess.leftCurlyBracketKeyword_2_1_1, regionAccess).append [
setNewLines(1,1,1);
increaseIndentation
for (EventAction element : p.additionalActions) {
format(element, doc);
//element.append[setNewLines(1,1,1)]
// p.regionForKeyword("}").prepend [
// newLine;decreaseIndentation
// ].append[setNewLines(1,1,1)]
p.regionForKeyword(ga.callServerProcedureCommandAccess.rightCurlyBracketKeyword_2_1_3, regionAccess).prepend [
p.regionForKeyword(ga.callServerProcedureCommandAccess.rightCurlyBracketKeyword_2_2, regionAccess).prepend [
def ISemanticRegion regionForKeyword(EObject owner, Keyword keyword, MyDslNodeModelBasedRegionAccess acc) {
val AbstractEObjectTokens tokens = acc.eObjectToTokens.get(owner);
if (tokens == null)
return null;
for (ISemanticRegion token : tokens.getTokens()) {
val AbstractElement element = token.getGrammarElement();
if (element instanceof Keyword) {
val Keyword kw = element;
if (kw.equals(keyword)) {
return token;
return null;
class MyDslNodeModelBasedRegionAccessBuilder extends NodeModelBasedRegionAccess.Builder {
override public NodeModelBasedRegionAccess create() {
val NodeModelBasedRegionAccess tokenAccess = new MyDslNodeModelBasedRegionAccess(this);
// System.out.println(tokenAccess);
return tokenAccess;
override public getEObjectToTokensMap(ITextRegionAccess tokenAccess) {
super.getEObjectToTokensMap(tokenAccess)
class MyDslNodeModelBasedRegionAccess extends NodeModelBasedRegionAccess {
protected new(MyDslNodeModelBasedRegionAccessBuilder builder) {
super(builder)
this.eObjectToTokens = ImmutableMap.copyOf(builder.getEObjectToTokensMap(this));
public val Map<EObject, AbstractEObjectTokens> eObjectToTokens;
def getEObjectTokens() {
return eObjectToTokens;
public class MyDslRuntimeModule extends org.xtext.example.mydsl1.AbstractMyDslRuntimeModule {
public Class<? extends NodeModelBasedRegionAccess.Builder> bindNodeModelBasedRegionAccess$Builder() {
return MyDslNodeModelBasedRegionAccessBuilder.class;
FUDForum. Page generated in 0.26642 seconds
