Home » Modeling » TMF (Xtext) » How to dynamic filter the content assistant list in XxxProposalProvider?
How to dynamic filter the content assistant list in XxxProposalProvider? [message #1692350] Wed, 15 April 2015 05:04 Go to next message
Hi all,
I have a ProposalProvider class.
"public class UclProposalProvider extends AbstractUclProposalProvider "
I also implement the complete function, which works.
	public void completeUclInstanceAttribute_Iafield(EObject model,
			Assignment assignment, ContentAssistContext context,
			ICompletionProposalAcceptor acceptor)
when I press ctrl+/, it can show the content assistant.
			ICompletionProposalAcceptor acceptor) {
in this function , I can get the prefix String(context.getPrefix()) if I input some char before trigger the content assistant.
My problem is that how to refresh the list in the content assistant when I input the char dynamically.
I wish it just dynamically display the item that start with prefix like JDT editor.
I think Xtext support this feature, But I can't find the guide.
Thanks!
Re: How to dynamic filter the content assistant list in XxxProposalProvider? [message #1692355 is a reply to message #1692350] Wed, 15 April 2015 05:20 Go to previous messageGo to next message
xtext does the prefix filtering automatically thus you should actually do not need to do anything
maybe you can show what you want to achive by an example to get a better idea
Re: How to dynamic filter the content assistant list in XxxProposalProvider? [message #1692356 is a reply to message #1692355] Wed, 15 April 2015 05:33 Go to previous messageGo to next message
Hi Christian,
if it is a cross reference, it is work automatically.
Before I can't use cross reference in this Object, the proposal is created by myself.
this a segment code in the function completeUclInstanceAttribute_Iafield.
EList<UclClassMember> members = ((UclClass) parentUclType)
					.getMembers();
			for (UclClassMember member : members) {
				UclClassField field = (UclClassField) member;
				UclType fieldType = field.getType();
				String replacement = field.getName();
				int cursorPosition = replacement.length();
				if (fieldType instanceof UclEnum) {
					replacement = field.getName() + " : ";
				else if (field.getMaxSize() != null) {
					replacement = field.getName() + "[  ];";
					cursorPosition = replacement.length() - 3;
				} else if (fieldType.getName().equals("Double")
						|| fieldType.getName().equals("Long")
						|| fieldType.getName().equals("Float")
						|| fieldType.getName().equals("Int")
						|| fieldType.getName().equals("String")
						|| fieldType.getName().equals("JavaScript")
						|| fieldType.getName().equals("Boolean")) {
				} else {
					replacement = field.getName() + "{\n  \n};";
					cursorPosition = replacement.length() - 4;
				String keyExt;
				if (field.getIsRequired() != null) {
					keyExt = "*";
				} else {
					keyExt = "";
				String key = field.getName();
				String additional = field.getType().getName() + " "
						+ field.getName();
				if (field.getType().getName().equals("JavaScript")) {
					additional += "\nExample:\naction:\"/src/hello.js\"";
				if(context.getPrefix()!=null && context.getPrefix().length()>0 && key.startsWith(context.getPrefix()))
					ConfigurableCompletionProposal cp = createDalProposal(model,
							replacement, key, keyExt, additional, cursorPosition,
							context);
					acceptor.accept(cp);
				else if(context.getPrefix()==null || context.getPrefix().length()==0)
							context);
it can filter at first time( I have input the prefix before trigger the content assistant).
but it can't refresh when I input the new char if it has been triggered.
thank your reply.
Re: How to dynamic filter the content assistant list in XxxProposalProvider? [message #1692357 is a reply to message #1692356] Wed, 15 April 2015 05:36 Go to previous messageGo to next message
i still cannot reproduce that.
the following Example Works fine for me
Model:
	value=ID
class MyDslProposalProvider extends AbstractMyDslProposalProvider {
	override completeModel_Value(EObject model, Assignment assignment, ContentAssistContext context, ICompletionProposalAcceptor acceptor) {
		super.completeModel_Value(model, assignment, context, acceptor)
		acceptor.accept(createCompletionProposal("aaa", context))
		acceptor.accept(createCompletionProposal("aab", context))
		acceptor.accept(createCompletionProposal("aba", context))
		acceptor.accept(createCompletionProposal("abb", context))
Re: How to dynamic filter the content assistant list in XxxProposalProvider? [message #1692426 is a reply to message #1692356] Wed, 15 April 2015 11:39 Go to previous messageGo to next message
Here you are using the prefix only once. If a char is entered, your
produced proposal will be checked against the new prefix by Xtext. Since
you do this manually, that functionality is lost.
You may want to set a custom prefix matcher on the produced proposal.
That prefix matcher will be queried afterwards.
See ConfigurableCompletionProposal.setMatcher
Best,
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Find help at http://xtext.itemis.com or xtext(@)itemis.com
Blog: zarnekow.blogspot.com
Twitter: @szarnekow
Google+: https://www.google.com/+SebastianZarnekow
Re: How to dynamic filter the content assistant list in XxxProposalProvider? [message #1695394 is a reply to message #1692426] Wed, 13 May 2015 21:29 Go to previous message
Thank Sebastian!
I solved it according to your help.
		ConfigurableCompletionProposal cp = new ConfigurableCompletionProposal(
				replacementString, replacementOffset, replacementLength,
				cursorPosition, img, displayString, null,
				additionalProposalInfo);
		cp.setMatcher(uclMatcher);
public class UclPrefixMatcher extends PrefixMatcher {
	public boolean isCandidateMatchingPrefix(String name, String prefix) {
		return name.regionMatches(true, 0, prefix, 0, prefix.length());
Previous Topic:Formatter2: formatting merging
Next Topic:Using annotations in DSL
Current Time: Sat Jul 19 05:43:00 EDT 2025
Powered by FUDForum. Page generated in 0.07109 seconds
