Home » Modeling » EMF » Dynamic EMF
Dynamic EMF [message #400487] Fri, 21 April 2006 06:24 Go to next message
I am just playing around with Dynamic EMF. I try to add an attribute to
the UML2 message class.
The Syso statement returns the added attribute, but calling eSet(...)
raises an exception. Why?
EAttribute attr = EcoreFactory.eINSTANCE.createEAttribute();
attr.setName("testAttribute");
attr.setEType(EcorePackage.eINSTANCE.getEString());
EClass messageClass = UML2Package.eINSTANCE.getMessage();
messageClass.getEStructuralFeatures().add(attr);
Message m = UML2Factory.eINSTANCE.createMessage();
System.out.println(m.eClass().getEStructuralFeature("testAttribute "));
m.eSet(attr,"foo");
Exception in thread "main" java.lang.NullPointerException
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eDerivedStructur alFeatureID(BasicEObjectImpl.java:780)
at org.eclipse.uml2.impl.MessageImpl.eGet(MessageImpl.java:614)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:483)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eOpenSet(BasicEO bjectImpl.java:549)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eDynamicSet(Basi cEObjectImpl.java:532)
at org.eclipse.uml2.impl.MessageImpl.eSet(MessageImpl.java:720)
Re: Dynamic EMF [message #400491 is a reply to message #400487] Fri, 21 April 2006 07:40 Go to previous messageGo to next message
Jens,
Ouch. You can't directly modify a generated class. You can extend any
class with a new class, add attributes to that new class, and then
create instances of that. (And once you've created an instance of a
class, you can no longer modify that class either.)
Jens wrote:
> Hello,
> to the UML2 message class.
> m.eSet(attr,"foo");
> at
> at
> at
> at
Re: Dynamic EMF [message #400492 is a reply to message #400491] Fri, 21 April 2006 08:12 Go to previous messageGo to next message
ok, but then I am wondering why
m.eClass().getEStructuralFeature("testAttribute") returns the attribute
of my extension.
Jens
Ed Merks wrote:
> Jens,
> Jens wrote:
>> Hello,
>> m.eSet(attr,"foo");
>> at
>> at
>> at
>> at
Re: Dynamic EMF [message #400493 is a reply to message #400492] Fri, 21 April 2006 08:37 Go to previous messageGo to next message
Jens,
I guess you interpreted my "you can't do that" answer as "it's
impossible to do that" when what I meant is "it's a really bad thing
that you should never do because you've just corrupted the one shared
instance of the meta data for the UML2 model that the whole JVM is using
and it won't really do all the things you are expecting."
> attribute of my extension.
> Jens
> Ed Merks wrote:
>> Jens,
>> any class with a new class, add attributes to that new class, and
>> then create instances of that. (And once you've created an instance
>> of a class, you can no longer modify that class either.)
>> Jens wrote:
>>> Hello,
>>> eSet(...) raises an exception. Why?
>>> m.eSet(attr,"foo");
>>> at
>>> at
>>> at
>>> at
Re: Dynamic EMF [message #1692277 is a reply to message #400493] Tue, 14 April 2015 12:59 Go to previous messageGo to next message
Hi Ed,
what if we want to do it anyway ?
Suppose I'm not playing with the UML2 blahblah but with a personnal Metamodel I want to evolve during an execution....
How to get rid of that null pointer ?
Re: Dynamic EMF [message #1692309 is a reply to message #1692277] Wed, 15 April 2015 00:19 Go to previous message
Edoaurd,
Comments below.
On 14/04/2015 6:59 PM, Edoaurd Batot wrote:
> Hi Ed,
It doesn't work.
Use a dynamic model all the time.
Java supports things like hot replace when debugging, but even there,
you can't add a field to a Java class and still hot replace it. You can
want to do it, but that desire itself doesn't make it possible in practice.
Previous Topic:The feature is not a valid feature. (java.lang.IllegalArgumentException)
Next Topic:Importing EMF models into Java through code
Current Time: Sat Jul 19 18:25:25 EDT 2025
Powered by FUDForum. Page generated in 0.04476 seconds
