Home » Modeling » TMF (Xtext) » eContainer becomes null after model transformation(eContainer becomes null after model transformation)
icon5.gif  eContainer becomes null after model transformation [message #1692263] Tue, 14 April 2015 11:53 Go to next message
Hi all,
I have a language something like:
entity MyEntity {
x=5
MyObj[x] {
So when generators are called I transform my model and MyObj[x] will be transformed to 5 copies . Something like MyObj_1, MyObj_2, MyObj_3, MyObj_4 and MyObj_5.
And then I set the new references created and remove the old reference from entity MyEntity I.e. my root object.
But after transformation all the 5 objects loses eContainer information and it becomes null... Any idea and suggestions?
Thanks for any help Smile
Re: eContainer becomes null after model transformation [message #1692264 is a reply to message #1692263] Tue, 14 April 2015 11:56 Go to previous messageGo to next message
Please provide more information, e.g how do you trigger your code /
transformation?
Best,
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Find help at http://xtext.itemis.com or xtext(@)itemis.com
Blog: zarnekow.blogspot.com
Twitter: @szarnekow
Google+: https://www.google.com/+SebastianZarnekow
Re: eContainer becomes null after model transformation [message #1692269 is a reply to message #1692263] Tue, 14 April 2015 12:32 Go to previous messageGo to next message
Seems like a classic case of child-stealing.
See page 6 of
https://www.eclipse.org/mmt/qvt/docs/ICMT2014/QVTtraceability.pdf.
Put
protected void eBasicSetContainer(InternalEObject newContainer, int
newContainerFeatureID) {
if (newContainer != null) {
EObject oldContainer = eInternalContainer();
assert (oldContainer == null) || oldContainer.eIsProxy() ||
(newContainer == oldContainer) || (oldContainer.eResource() == null);
super.eBasicSetContainer(newContainer, newContainerFeatureID);
in your root EObjectImpl and it'll show you where it happens.
Ed Willink
On 14/04/2015 16:53, Arshad Adavani wrote:
> Hi all,
> entity MyEntity {
> x=5
> MyObj[x] {
> Thanks for any help :)
Re: eContainer becomes null after model transformation [message #1692275 is a reply to message #1692264] Tue, 14 April 2015 12:56 Go to previous messageGo to next message
Hi Sebastian,
Thanks for your reply..
After the save of the file, when dogenerate() method is called, I call a function to transform my model.
Here I do nothing special than using,
var newObj=EcoreUtil.copy(original object)
And then renaming newObj.name to MyObj_1, so on..
And after this i have eContainer set to null...
Not sure what's going wrong..
Arshad
Re: eContainer becomes null after model transformation [message #1692294 is a reply to message #1692275] Tue, 14 April 2015 17:05 Go to previous message
#doGenerate is not supposed to modify the resource. You may want to
create a copy, manipulate that and save it afterwards. That would
probably work for you. I'm still not sure what you expected from that
transformation or what you wanted to do with the transformation result.
Information like this would help to give better advice.
Best,
Sebastian
Twitter: @szarnekow
Previous Topic:syntactic predicates / references
Next Topic:if/elsif
Current Time: Sat Jul 19 08:48:28 EDT 2025
Powered by FUDForum. Page generated in 0.05984 seconds
