Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Easiest way to deploy a generator
[Acceleo] Easiest way to deploy a generator [message #1692185] |
Tue, 14 April 2015 04:28  |
I've created a small generator and it works within my development instance of eclipse.
Now I want to deploy it and naively, I simply try to export the two projects (generator and generator.ui) by the export wizard: Deployable plug-ins and fragments.
Installing the generated plugins into a different eclipse instance leads to the error message that some *.emtl file can not be found. I modified build.properties such that this file is added into the exported plugins. I actually verified that. Still, running the generator results in the same error message; just as if the generator does not look 'at the right place'.
I am aware of https://www.eclipse.org/forums/index.php/t/812368/ but I'm not using Maven so far and I think that setting up such build infrastructure is not justified for the case of exporting a small simple generator.
Actually I have two questions:
1) Can I solve the 'emtl not found' problem without using maven (and if yes, how)?
2) Why is the simple deployable plugin export not supported anymore?
Greetings,
Wilbert.
Re: [Acceleo] Easiest way to deploy a generator [message #1692196 is a reply to message #1692185] |
Tue, 14 April 2015 05:17   |
IIRC, before I converted all my Acceleo templates to Xtend, I worked
around the problem by manually switching between two build behaviours.
During 'interactive' development, I let Acceleo build the *.emtl files
normally, with the occasional clean/build-all encouragement. When happy,
I copied bin/.../*.emtl to src2/..../*.emtl.
For release deployment I treated the *.emtl files as sources files, by
disabling the Acceleo builder and instead relying on the Java builder to
copy src2/..../*.emtl to bin/.../*.emtl.
Switching involved adding/removing the Acceleo nature and builder, and
adding/removing "customBuildCallbacks = build.acceleo
" in build.properties.
You can look at commit ee770a838361c879d3c24e2b024fb186872c1e45 of
https://git.eclipse.org/r/ocl/org.eclipse.ocl to see a behaviour switch
that accidentally got committed.
Ed Willink
On 14/04/2015 09:28, Wilbert Alberts wrote:
> simple generator.
> if yes, how)?
> Greetings,
> Wilbert.
Re: [Acceleo] Easiest way to deploy a generator [message #1692215 is a reply to message #1692196] |
Tue, 14 April 2015 07:10   |
I have the same problem. Currently, I'm putting manually the emtl files
in the right folder of the jar file.
When you select in the Overview of your plugin.xml to include the emtl
files into the build, please notice they are copied into /bin/<your
packages> into the jar file, instead of just /<your package> as needed
for the plugin to work.
Currently, I don't know how to provide an easier solution than doing it
manually.
Best,
Víctor
El 14/04/2015 a las 11:17, Ed Willink escribió:
> Hi
> Regards
> Ed Willink
>> Hi,
>> simple generator.
>> if yes, how)?
>> Greetings,
>> Wilbert.
Re: [Acceleo] Easiest way to deploy a generator [message #1692218 is a reply to message #1692215] |
Tue, 14 April 2015 07:29  |
The Java classpath settings control what gets copied and to what
directories.
Properties->Java Build Path.
Ed Willink
On 14/04/2015 12:10, "V. López" wrote:
> files in the right folder of the jar file.
> it manually.
> Best,
> Víctor
>> Hi
>> Regards
>> Ed Willink
>>> Hi,
>>> simple generator.
>>> if yes, how)?
>>> Greetings,
>>> Wilbert.
Current Time: Sat Jul 19 11:27:00 EDT 2025
Powered by FUDForum. Page generated in 0.04554 seconds
