Need an Eclipse / Appium Expert [message #1691959] |
Fri, 10 April 2015 19:06 |
So I've been able to learn and create plenty of scripts on Eclipse that run perfectly well on any web browser I need.
I've now moved onto mobile automation, since from my research I discovered the tool Appium can interpret the selenium syntax, so I won't need to learn a new language.
So I wrote my script into Eclipse using selenium, and now I want it to run on Appium. It was working as intended, until it stopped and said there are no JUnity 4 cases to run. I've make the folder "use as source folder" and that usually works, but not this time.
Now do I run it as a Junit or a Java Application? And if an application, it asks for a main, and I don't know what to choose.
I had it working previously, but that was because it chose the method automatically, but for some reason its not anymore.
If anyone is seasoned with Appium and eclipse working together, i need help.
FUDForum. Page generated in 0.24021 seconds
