Home » Eclipse Projects » RCP Testing Tool » [SOLVED] Use of regular expression to detect widget
[SOLVED] Use of regular expression to detect widget [message #1691791] Thu, 09 April 2015 12:07 Go to next message
Is it possible to use regular expression to detect a widget ?
For example :
get-button "Configure Session... (.*)"
Thanks in advance,
Maherzia
[Updated on: Mon, 05 October 2015 02:32] by Moderator
Re: Use of regular expression to detect widget [message #1691829 is a reply to message #1691791] Thu, 09 April 2015 23:10 Go to previous messageGo to next message
Hi Maherzia,
Sure, you can use it in the following way (no brackets needed):
get-button "Configure Session.*" or get-button "Configure .*"
Yours sincerely,
Ulyana.
Re: Use of regular expression to detect widget [message #1691931 is a reply to message #1691829] Fri, 10 April 2015 09:43 Go to previous message
Thanks !
Previous Topic:[SOLVED] RCPTT terminates execution if any assertion fails in a test case
Next Topic:[SOLVED] Is there any way to use verifications in between a test case ?
Current Time: Sat Jul 19 20:52:07 EDT 2025
Powered by FUDForum. Page generated in 0.04349 seconds
