Home » Modeling » TMF (Xtext) » xtext-32 bits does not start(dsl application does not start)
xtext-32 bits does not start [message #1691641] Wed, 08 April 2015 12:59 Go to next message
Hello All
I observed the following problem. I have to ported xtext application to 32 bit platform. All develpoment is provided on 64 xtext distribuition. I made the following
- download Xtext 32 bits distribution
- create new workspace
- copy my source code to this new workspace
- clean
- build application
- run appliccation via product file
then I observe the following error. Would make any advises regardint this issue
By the way 64 bits version of application works OK
!SESSION 2015-04-08 19:49:25.004 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_40
Framework arguments: -product com.psl.atom.product
Command-line arguments: -product com.psl.atom.product -data C:\Users\agorlov\Documents\workspaces\atom-std-32/../runtime-AtomProduct.product -dev file:C:/Users/agorlov/Documents/workspaces/atom-std-32/.metadata/.plugins/org.eclipse.pde.core/AtomProduct.product/dev.properties -os win32 -ws win32 -arch x86 -consoleLog
!ENTRY org.eclipse.osgi 4 0 2015-04-08 19:49:26.414
!MESSAGE An error occurred while automatically activating bundle org.eclipse.ui.workbench (96).
!STACK 0
org.osgi.framework.BundleException: Error starting module.
at org.eclipse.osgi.container.Module.doStart(Module.java:580)
at org.eclipse.osgi.container.Module.start(Module.java:439)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:454)
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:531)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:324)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:320)
at org.eclipse.osgi.internal.loader.sources.SingleSourcePackage.loadClass(SingleSourcePackage.java:36)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:391)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:345)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:337)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:160)
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Unknown Source)
at java.lang.Class.getConstructor0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:184)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:191)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
at org.eclipse.equinox.launcher.Main.main(Main.java:1438)
Caused by: java.lang.NoClassDefFoundError: org/eclipse/swt/SWTError
at org.eclipse.osgi.internal.framework.BundleContextImpl.loadBundleActivator(BundleContextImpl.java:755)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:706)
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:936)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:319)
at org.eclipse.osgi.container.Module.doStart(Module.java:571)
... 33 more
Caused by: java.lang.ClassNotFoundException: org.eclipse.swt.SWTError cannot be found by org.eclipse.ui.workbench_3.106.2.v20150204-1030
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:432)
... 42 more
Root exception:
... 42 more
!ENTRY org.eclipse.osgi 4 0 2015-04-08 19:49:26.434
!MESSAGE Application error
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in "org.eclipse.ui.ide.application" was unable to instantiate class "org.eclipse.ui.internal.ide.application.IDEApplication".
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:188)
Caused by: java.lang.NoClassDefFoundError: org/eclipse/ui/application/WorkbenchAdvisor
... 16 more
Caused by: java.lang.ClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.ui.workbench (96).
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:116)
... 21 more
Caused by: org.osgi.framework.BundleException: Error starting module.
... 30 more
... 33 more
... 42 more
[Updated on: Wed, 08 April 2015 12:59] by Moderator
Re: xtext-32 bits does not start [message #1691645 is a reply to message #1691641] Wed, 08 April 2015 13:10 Go to previous messageGo to next message
do you use a 32 bit vm as well in your launch config? do you use a custom target platform?
Re: xtext-32 bits does not start [message #1691647 is a reply to message #1691645] Wed, 08 April 2015 13:14 Go to previous messageGo to next message
I use 32 bits vm
apllication configuration file is
-vm
./jre/bin/javaw.exe
-startup
plugins/org.eclipse.equinox.launcher_1.3.0.v20140415-2008.jar
--launcher.library
plugins/org.eclipse.equinox.launcher.win32.win32.x86_1.1.200.v20150204-1316
-showsplash
also
I've set 32-bits jre in product file
Re: xtext-32 bits does not start [message #1691650 is a reply to message #1691647] Wed, 08 April 2015 13:26 Go to previous messageGo to next message
strange. but please revisit the run config: are 32 bit swt plugins checked and is the vm a 32 bit? or does the error occur when you run the exe of the product?
Re: xtext-32 bits does not start [message #1691707 is a reply to message #1691647] Thu, 09 April 2015 04:15 Go to previous messageGo to next message
I've tried to run on clear 32-bits computer with Windows 7 32-bits. And observed the same result
Re: xtext-32 bits does not start [message #1691709 is a reply to message #1691707] Thu, 09 April 2015 04:20 Go to previous messageGo to next message
what happens ich you right-click a plugin and select run as -> eclipse application?
Re: xtext-32 bits does not start [message #1691718 is a reply to message #1691709] Thu, 09 April 2015 05:34 Go to previous messageGo to next message
I've tried to start ui plugin that generated by Xtext. Plugin started without problem
Re: xtext-32 bits does not start [message #1691719 is a reply to message #1691709] Thu, 09 April 2015 05:35 Go to previous messageGo to next message
I've tried to start ui plugin that generated by Xtext. Application is started without problem.
Re: xtext-32 bits does not start [message #1691730 is a reply to message #1691719] Thu, 09 April 2015 06:33 Go to previous messageGo to next message
Then there must be something wrong with your product or the launch config of the product
Re: xtext-32 bits does not start [message #1691733 is a reply to message #1691730] Thu, 09 April 2015 06:48 Go to previous messageGo to next message
Do you have any idea, regarding this problem? Which item in configuration can be wrong?
Re: xtext-32 bits does not start [message #1691737 is a reply to message #1691733] Thu, 09 April 2015 07:39 Go to previous messageGo to next message
In the launch config:
- the jvm on the first tab
- the plugin selection on the third tab
Re: xtext-32 bits does not start [message #1691777 is a reply to message #1691737] Thu, 09 April 2015 11:13 Go to previous messageGo to next message
I've found out the following plugin org.eclipse.swt.win32.win32.x86_3.103.2.v20150203-1351.jar was not flaged in Run configuration. When i've marked this plugin and set Start Level = default and AutoStart = false. I'm able to start application via run configuration insside IDE. But Apllication export wizard is not included it to distribution. How can I correctly configure export wizard for avoid this issue?
Re: xtext-32 bits does not start [message #1691795 is a reply to message #1691777] Thu, 09 April 2015 12:42 Go to previous messageGo to next message
how does your product file look file? you should be able to configure it
Re: xtext-32 bits does not start [message #1691854 is a reply to message #1691795] Fri, 10 April 2015 03:54 Go to previous message
Thanks Christian problem resolved
[Updated on: Fri, 10 April 2015 03:54] by Moderator
Previous Topic:How to remove Xtext nature of only few files in the project
Next Topic:Cann't get Array Type elements?
Current Time: Sat Jul 19 22:20:02 EDT 2025
Powered by FUDForum. Page generated in 0.06483 seconds
