Home » Eclipse Projects » Eclipse Platform » Update eclipse results in no menus, projects not visible - completely useless
Update eclipse results in no menus, projects not visible - completely useless [message #1691466] Tue, 07 April 2015 09:10 Go to next message
This is the second time this has happened.
I checked for updates, there was some ( I cannot remember what they were) but I updated.
When eclipse restarted, all menus were missing, files not showing, projects not showing.
http://i.imgur.com/BAbwXW1.png
How can I fix this?
And how can I prevent this from happening again?
Re: Update eclipse results in no menus, projects not visible - completely useless [message #1691488 is a reply to message #1691466] Tue, 07 April 2015 11:07 Go to previous messageGo to next message
Could you attach your log file? Looks like a major error must have occurred.
Brian.
Re: Update eclipse results in no menus, projects not visible - completely useless [message #1691492 is a reply to message #1691488] Tue, 07 April 2015 11:27 Go to previous messageGo to next message
Hi Brian
There is no log file, as described in the link you provided. But there is a platform.xml file, which I have attached.
  • Attachment: platform.xml
    (Size: 52.36KB, Downloaded 236 times)
Re: Update eclipse results in no menus, projects not visible - completely useless [message #1691500 is a reply to message #1691492] Tue, 07 April 2015 12:18 Go to previous messageGo to next message
That's not the file, unfortunately. Try searching your hard disk for a file called ".log". I'm not sure what platform you're on, but the default workspace is usually in your home directory called "workspace", so you'd look under there for ".metadata/.log". You may need to enable viewing hidden files.
Brian.
Re: Update eclipse results in no menus, projects not visible - completely useless [message #1691503 is a reply to message #1691500] Tue, 07 April 2015 12:27 Go to previous messageGo to next message
Found it.
And I am using Ubuntu 14.04
  • Attachment: .log
    (Size: 921.79KB, Downloaded 162 times)
Re: Update eclipse results in no menus, projects not visible - completely useless [message #1691524 is a reply to message #1691503] Tue, 07 April 2015 15:45 Go to previous message
Hmm, it looks like the update went very awry: what would seem to be a key dependency "org.eclipse.jpt.common.core" isn't found, and you have a bunch of ClassCastExceptions "java.lang.ClassCastException: org.eclipse.e4.ui.model.application.impl.ApplicationImpl cannot be cast to org.eclipse.emf.ecore.EObject" -- and those objects definitely do implement Object.
You might be able to do a "revert" using the p2 director. See the following FAQ:
https://wiki.eclipse.org/FAQ_Revert_an_Update_or_Installation_with_p2
Brian.
Previous Topic:Type Hierarchy doesn't show anything
Next Topic:[Solved] Help for customizing an eclipse context menu
Current Time: Sun Jul 20 07:39:24 EDT 2025
Powered by FUDForum. Page generated in 0.05387 seconds
