[ECP] Additional label alignment option "Top"? [message #1690959] |
Wed, 01 April 2015 06:00  |
we are working on the ECP-Implementation for Vaadin. In Vaadin, labels (captions) are displayed at the top by default, with the option to display them on the left using a FormLayout (or none at all, of course).
Examples for the AngularJS renderer also show labels at the top.
The ECP model provides the label alignment options "Left" and "None". Would it make sense to have an additional option "Top"? If so, can you add it?
Greetings
Matthias
[Updated on: Wed, 01 April 2015 06:35] by Moderator
Re: [ECP] Additional label alignment option "Top"? [message #1691219 is a reply to message #1690959] |
Fri, 03 April 2015 10:06   |
I assume you are talking about EMF Forms, right? You are right, we
should reconsider the options available for the label. Another option
would be to add an option "default", which leaves the label position to
th renderer. This would fit the current state. Could you open a Bug
Report to discuss this?
Thank you and best regards
Jonas
Am 01.04.2015 um 12:00 schrieb Matthias Juchmes:
> Hello,
> add it?
> Greetings
> Matthias
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
Re: [ECP] Additional label alignment option "Top"? [message #1691423 is a reply to message #1691219] |
Tue, 07 April 2015 04:16  |
yes, I'm talking about EMF Forms. Thanks for your answer, I created a Bug Report
Greetings
Matthias
Jonas Helming wrote on Fri, 03 April 2015 14:06Hi,
Jonas
> Hello,
> add it?
> Greetings
> Matthias
FUDForum. Page generated in 0.03532 seconds
