Home » Modeling » Papyrus » Plugin design in Papyrus
Plugin design in Papyrus [message #1690780] Tue, 31 March 2015 04:37 Go to next message
Hello
I want to do some plugin design in Papyrus Luna
First I tried the java refactor but it did not work with components.
Then
I created in a component diagram components corresponding to my plugins.
I created Interfaces inside my plugin and some classes.
First problem :
Inside inner class diagram it seems impossible to create Interface realization between Interfaces and classes.
My question is what is the best way to show that a plugin required an interface and the second one provide it. I know UML provided and required interfaces but I did not succeed to model them in Papyrus. Even using the "manage interfaces" action
Re: Plugin design in Papyrus [message #1691017 is a reply to message #1690780] Wed, 01 April 2015 11:15 Go to previous message
Hi Tristan,
First problem :
I guess the Inner Class Diagram is over-filtered compared to standard Class Diagram again. That can easily be fixed
Manage Interfaces (Or provided/required from the properties view) should work if you type your Port with a Class (Which, according to the specification, gives the maximum flexibility for deriving Provided/Required interfaces of the Port). I'm not sure if the edition of Provided/Required interfaces has been added in Luna or in Mars. If it's not available in Luna, then you should rely on the Manage Interfaces context menu (After typing the Port with a Class)
However, Papyrus doesn't support the Ball & Socket notation
Camille
Previous Topic:SWT error: Out of handles
Next Topic:How to transfer and import a Papyrus project
Current Time: Sat Jul 19 16:39:52 EDT 2025
Powered by FUDForum. Page generated in 0.03842 seconds
