Have the Project Catalogs gone off-line? [message #1690664] |
Mon, 30 March 2015 09:00  |
It appears that today the project catalogs have no content. Has
something gone off-line? Or is there some diagnostic information that
Oomph can give me about why I may not be able to see them from my
system today?
Christian
Re: Have the Project Catalogs gone off-line? [message #1690681 is a reply to message #1690671] |
Mon, 30 March 2015 11:07  |
On 2015-03-30 13:54:23 +0000, Ed Merks said:
> Christian,
> The installer's configuration folder contains logs so that's the first
> place to look.
Yes, I looked for that and found no log file of any kind in the
configuration folder, which is why I asked where to find diagnostic
information. :-)
> So the first page was okay and displayed the products?
Correct.
> You might also try clearing <home>/.eclipse/org.eclipse.oomph.setup/cache/*
That fixed me up. Thanks!
> Note that we've added logic to automatically refresh the remote
> resource cache, so perhaps there's a problem with that, which hopefully
> shows up in your log.
I would second that hypothesis. ;-) I had just updated to the latest
Oomph, which supports your theory.
Alas, no log, though. Wish I had something for you.
> What does your
> <home>/.eclipse/org.eclipse.oomph.setup/setups/catalogs.setup look like?
<setup:CatalogSelection
xmi:version="2.0"
xmlns:setup="http://www.eclipse.org/oomph/setup/1.0">
<productCatalog
href="index:/org.eclipse.setup#//@productCatalogs[name='org.eclipse.products']"/>
<projectCatalog
href="index:/org.eclipse.setup#//@projectCatalogs[name='org.eclipse']"/>
<projectCatalog
href="index:/org.eclipse.setup#//@projectCatalogs[name='com.github']"/>
<defaultProductVersion
key="index:/org.eclipse.setup#//@productCatalogs[name='org.eclipse.products']/@products[name='epp.package.committers']"
value="index:/org.eclipse.setup#//@productCatalogs[name='org.eclipse.products']/@products[name='epp.package.committers']/@versions[name='mars']"/>
key="index:/org.eclipse.setup#//@productCatalogs[name='org.eclipse.products']/@products[name='epp.package.modeling']"
value="index:/org.eclipse.setup#//@productCatalogs[name='org.eclipse.products']/@products[name='epp.package.modeling']/@versions[name='latest.released']"/>
key="index:/org.eclipse.setup#//@productCatalogs[name='org.eclipse.products']/@products[name='epp.package.standard']"
value="index:/org.eclipse.setup#//@productCatalogs[name='org.eclipse.products']/@products[name='epp.package.standard']/@versions[name='latest']"/>
key="index:/org.eclipse.setup#//@productCatalogs[name='org.eclipse.products']/@products[name='epp.package.php']"
value="index:/org.eclipse.setup#//@productCatalogs[name='org.eclipse.products']/@products[name='epp.package.php']/@versions[name='latest']"/>
key="index:/org.eclipse.setup#//@productCatalogs[name='org.eclipse.products']/@products[name='epp.package.java']"
value="index:/org.eclipse.setup#//@productCatalogs[name='org.eclipse.products']/@products[name='epp.package.java']/@versions[name='latest.released']"/>
</setup:CatalogSelection>
> This problem also occurs the second time you run the installer?
Every time. Until I fixed it by deleting the cache.
Thanks for your help!
Christian
> On 30/03/2015 3:00 PM, Christian W. Damus wrote:
>> Hi,
>> system today?
>> Thanks,
>> Christian
FUDForum. Page generated in 0.04351 seconds
