Home » Eclipse Projects » e(fx)clipse » Eclipse crash on AIX(Eclipse is causing java dump without any module indication and crashes immediately after starting IBM installation Manager)
Eclipse crash on AIX [message #1690552] Sat, 28 March 2015 13:15 Go to next message
I am trying to run IBM installation manager 1.8.1 which uses gtk libraries.
the required GTK libraries are already installed -
mtools-3.9.7-4
info-4.6-1
zip-2.3-3
gzip-1.4-1
unzip-5.51-1
cairo-1.10.0-1
zlib-1.2.7-1
expat-2.0.1-2
gpe-agent-nmon-2.5-8
freetype2-2.3.9-1
fontconfig-2.4.2-1
atk-1.12.3-2
libpng-1.2.32-2
glib2-2.14.6-2
gettext-0.10.40-8
gpe-agent-comm-2.4-2
libtiff-3.8.2-1
AIX-rpm-7.1.3.0-12
libjpeg-6b-6
xrender-0.9.1-3
xft-2.1.6-5
pango-1.14.5-4
xcursor-1.1.7-3
pixman-0.20.0-1
gtk2-2.10.6-5
vnc-3.3.3r2-6
JRE 7.0.7001
Installation Manager is 32 bit and AIX is PPC 64
0SECTION TITLE subcomponent dump routine
NULL ===============================
1TICHARSET ISO8859-1
1TISIGINFO Dump Event "gpf" (00002000) received
1TIDATETIME Date: 2015/03/28 at 12:51:07
1TIFILENAME Javacore filename: /opt/IBM/InstallationManager/eclipse/javacore.20150328.125107.10223796.0002.txt
1TIREQFLAGS Request Flags: 0x81 (exclusive+preempt)
1TIPREPSTATE Prep State: 0x100 (trace_disabled)
1TIPREPINFO Exclusive VM access not taken: data may not be consistent across javacore sections
NULL ------------------------------------------------------------------------
0SECTION GPINFO subcomponent dump routine
NULL ================================
2XHOSLEVEL OS Level : AIX 7.1
2XHCPUS Processors -
3XHCPUARCH Architecture : ppc
3XHNUMCPUS How Many : 4
3XHNUMASUP NUMA is either not supported or has been disabled by user
NULL
1XHEXCPCODE J9Generic_Signal_Number: 00000004
1XHEXCPCODE Signal_Number: 0000000B
1XHEXCPCODE Error_Value: 00000000
1XHEXCPCODE Signal_Code: 00000033
1XHEXCPCODE Handler1: F12CB04C
1XHEXCPCODE Handler2: F12C4180
NULL
NULL
1XHREGISTERS Registers:
1XHFLAGS VM flags:00040000
NULL
0SECTION ENVINFO subcomponent dump routine
NULL =================================
1CIJAVAVERSION JRE 1.7.0 AIX ppc-32 build (pap3270sr7fp1-20140708_01(SR7 FP1) )
1CIVMVERSION VM build R26_Java726_SR7_20140627_0924_B204598
1CIJITVERSION r11.b06_20140409_61252.04
1CIGCVERSION GC - R26_Java726_SR7_20140627_0924_B204598
1CIJITMODES JIT enabled, AOT enabled, FSD disabled, HCR disabled
1CIRUNNINGAS Running as a standalone JVM
1CIPROCESSID Process ID: 10223796 (0x9C00B4)
1CICMDLINE /opt/IBM/InstallationManager/eclipse/jre_7.0.7001.20140909_1712/jre/bin/java -Xms40m -Xmx512m -Xquickstart -Xgcpolicy:gencon -jar /opt/IBM/InstallationManager/eclipse/plugins/org.eclipse.equinox.launcher_1.3.0.v20130327-1446.jar -os aix -ws gtk -arch ppc -showsplash -launcher /opt/IBM/InstallationManager/eclipse/IBMIM -name IBMIM --launcher.library /opt/IBM/InstallationManager/eclipse/plugins/org.eclipse.equinox.launcher.gtk.aix.ppc_1.1.100.v20120522-1822/eclipse_1502.so -startup /opt/IBM/InstallationManager/eclipse/plugins/org.eclipse.equinox.launcher_1.3.0.v20130327-1446.jar --launcher.overrideVmargs -exitdata 100045 -toolId ibmim -accessRights nonAdmin -Dorg.eclipse.swt.internal.gtk.cairoGraphics=false -vm /opt/IBM/InstallationManager/eclipse/jre_7.0.7001.20140909_1712/jre/bin/java -vmargs -Xms40m -Xmx512m -Xquickstart -Xgcpolicy:gencon -jar /opt/IBM/InstallationManager/eclipse/plugins/org.eclipse.equinox.launcher_1.3.0.v20130327-1446.jar
1CIJAVAHOMEDIR Java Home Dir: /opt/IBM/InstallationManager/eclipse/jre_7.0.7001.20140909_1712/jre
1CIJAVADLLDIR Java DLL Dir: /opt/IBM/InstallationManager/eclipse/jre_7.0.7001.20140909_1712/jre/bin
1CISYSCP Sys Classpath: /opt/IBM/InstallationManager/eclipse/jre_7.0.7001.20140909_1712/jre/lib/ppc/default/jclSC170/vm.jar;/opt/IBM/InstallationManager/eclipse/jre_7.0.7001.20140909_1712/jre/lib/se-service.jar;/opt/IBM/InstallationManager/eclipse/jre_7.0.7001.20140909_1712/jre/lib/math.jar;/opt/IBM/InstallationManager/eclipse/jre_7.0.7001.20140909_1712/jre/lib/jlm.jar;/opt/IBM/InstallationManager/eclipse/jre_7.0.7001.20140909_1712/jre/lib/ibmorb.jar;/opt/IBM/InstallationManager/eclipse/jre_7.0.7001.20140909_1712/jre/lib/ibmorbapi.jar;/opt/IBM/InstallationManager/eclipse/jre_7.0.7001.20140909_1712/jre/lib/ibmcfw.jar;/opt/IBM/InstallationManager/eclipse/jre_7.0.7001.20140909_1712/jre/lib/ibmpkcs.jar;/opt/IBM/InstallationManager/eclipse/jre_7.0.7001.20140909_1712/jre/lib/ibmcertpathfw.jar;/opt/IBM/InstallationManager/eclipse/jre_7.0.7001.20140909_1712/jre/lib/ibmjgssfw.jar;/opt/IBM/InstallationManager/eclipse/jre_7.0.7001.20140909_1712/jre/lib/ibmjssefw.jar;/opt/IBM/InstallationManager/eclipse/jre_7.0.7001.20140909_1712/jre/lib/ibmsaslfw.jar;/opt/IBM/InstallationManager/eclipse/jre_7.0.7001.20140909_1712/jre/lib/ibmjcefw.jar;/opt/IBM/InstallationManager/eclipse/jre_7.0.7001.20140909_1712/jre/lib/ibmjgssprovider.jar;/opt/IBM/InstallationManager/eclipse/jre_7.0.7001.20140909_1712/jre/lib/ibmjsseprovider2.jar;/opt/IBM/InstallationManager/eclipse/jre_7.0.7001.20140909_1712/jre/lib/ibmcertpathprovider.jar;/opt/IBM/InstallationManager/eclipse/jre_7.0.7001.20140909_1712/jre/lib/xmldsigfw.jar;/opt/IBM/InstallationManager/eclipse/jre_7.0.7001.20140909_1712/jre/lib/xml.jar;/opt/IBM/InstallationManager/eclipse/jre_7.0.7001.20140909_1712/jre/lib/charsets.jar;/opt/IBM/InstallationManager/eclipse/jre_7.0.7001.20140909_1712/jre/lib/resources.jar;/opt/IBM/InstallationManager/eclipse/jre_7.0.7001.20140909_1712/jre/lib/rt.jar;
1CIUSERARGS UserArgs:
2CIUSERARG -Xoptionsfile=/opt/IBM/InstallationManager/eclipse/jre_7.0.7001.20140909_1712/jre/lib/ppc/default/options.default
2CIUSERARG -Xlockword:mode=default,noLockword=java/lang/String,noLockword=java/util/MapEntry,noLockword=java/util/HashMap$Entry,noLockword=org/apache/harmony/luni/util/ModifiedMap$Entry,noLockword=java/util/Hashtable$Entry,noLockword=java/lang/invoke/MethodType,noLockword=java/lang/invoke/MethodHandle,noLockword=java/lang/invoke/CollectHandle,noLockword=java/lang/invoke/ConstructorHandle,noLockword=java/lang/invoke/ConvertHandle,noLockword=java/lang/invoke/ArgumentConversionHandle,noLockword=java/lang/invoke/AsTypeHandle,noLockword=java/lang/invoke/ExplicitCastHandle,noLockword=java/lang/invoke/FilterReturnHandle,noLockword=java/lang/invoke/DirectHandle,noLockword=java/lang/invoke/ReceiverBoundHandle,noLockword=java/lang/invoke/DynamicInvokerHandle,noLockword=java/lang/invoke/FieldHandle,noLockword=java/lang/invoke/FieldGetterHandle,noLockword=java/lang/invoke/FieldSetterHandle,noLockword=java/lang/invoke/StaticFieldGetterHandle,noLockword=java/lang/invoke/StaticFieldSetterHandle,noLockword=java/lang/invoke/IndirectHandle,noLockword=java/lang/invoke/InterfaceHandle,noLockword=java/lang/invoke/VirtualHandle,noLockword=java/lang/invoke/InvokeExactHandle,noLockword=java/lang/invoke/InvokeGenericHandle,noLockword=java/lang/invoke/VarargsCollectorHandle,noLockword=java/lang/invoke/ThunkTuple
2CIUSERARG -Xjcl:jclse7b_26
2CIUSERARG -Dcom.ibm.oti.vm.bootstrap.library.path=/opt/IBM/InstallationManager/eclipse/jre_7.0.7001.20140909_1712/jre/lib/ppc/default:/opt/IBM/InstallationManager/eclipse/jre_7.0.7001.20140909_1712/jre/lib/ppc
2CIUSERARG -Dsun.boot.library.path=/opt/IBM/InstallationManager/eclipse/jre_7.0.7001.20140909_1712/jre/lib/ppc/default:/opt/IBM/InstallationManager/eclipse/jre_7.0.7001.20140909_1712/jre/lib/ppc
2CIUSERARG -Djava.library.path=/opt/IBM/InstallationManager/eclipse/jre_7.0.7001.20140909_1712/jre/lib/ppc/default:/opt/IBM/InstallationManager/eclipse/jre_7.0.7001.20140909_1712/jre/lib/ppc:/opt/IBM/InstallationManager/eclipse/jre_7.0.7001.20140909_1712/jre/lib/ppc:/opt/IBM/InstallationManager/eclipse/jre_7.0.7001.20140909_1712/jre/lib/ppc/default:/opt/IBM/InstallationManager/eclipse/jre_7.0.7001.20140909_1712/jre/lib/ppc/j9vm:/opt/IBM/InstallationManager/eclipse/jre_7.0.7001.20140909_1712/jre/lib/ppc:/opt/IBM/InstallationManager/eclipse/jre_7.0.7001.20140909_1712/jre/../lib/ppc:/oracle/client/12.1/lib:/usr/dt/lib:/usr/openwin/lib:/usr/lib:/oracle/client/12.1/lib:/usr/bin/lib:/usr/dt/lib:/usr/openwin/lib:/usr/lib
2CIUSERARG -Djava.home=/opt/IBM/InstallationManager/eclipse/jre_7.0.7001.20140909_1712/jre
2CIUSERARG -Djava.ext.dirs=/opt/IBM/InstallationManager/eclipse/jre_7.0.7001.20140909_1712/jre/lib/ext
2CIUSERARG -Duser.dir=/opt/IBM/InstallationManager/eclipse
2CIUSERARG _j2se_j9=1120000 0xF12BA5B4
2CIUSERARG -Djava.runtime.version=pap3270sr7fp1-20140708_01 (SR7 FP1)
2CIUSERARG -Djava.class.path=/oracle/client/12.1/jdbc/lib:/oracle/client/12.1/jlib:/oracle/client/12.1/sqlj/lib:/oracle/client/12.1/jdbc/lib:.
2CIUSERARG -Xms40m
2CIUSERARG -Xmx512m
2CIUSERARG -Xquickstart
2CIUSERARG -Xgcpolicy:gencon
2CIUSERARG -Djava.class.path=/opt/IBM/InstallationManager/eclipse/plugins/org.eclipse.equinox.launcher_1.3.0.v20130327-1446.jar
2CIUSERARG -Dsun.java.command=/opt/IBM/InstallationManager/eclipse/plugins/org.eclipse.equinox.launcher_1.3.0.v20130327-1446.jar -os aix -ws gtk -arch ppc -showsplash -launcher /opt/IBM/InstallationManager/eclipse/IBMIM -name IBMIM --launcher.library /opt/IBM/InstallationManager/eclipse/plugins/org.eclipse.equinox.launcher.gtk.aix.ppc_1.1.100.v20120522-1822/eclipse_1502.so -startup /opt/IBM/InstallationManager/eclipse/plugins/org.eclipse.equinox.launcher_1.3.0.v20130327-1446.jar --launcher.overrideVmargs -exitdata 100045 -toolId ibmim -accessRights nonAdmin -Dorg.eclipse.swt.internal.gtk.cairoGraphics=false -vm /opt/IBM/InstallationManager/eclipse/jre_7.0.7001.20140909_1712/jre/bin/java -vmargs -Xms40m -Xmx512m -Xquickstart -Xgcpolicy:gencon -jar /opt/IBM/InstallationManager/eclipse/plugins/org.eclipse.equinox.launcher_1.3.0.v20130327-1446.jar
2CIUSERARG -Dsun.java.launcher=SUN_STANDARD
2CIUSERARG _port_library 0xF12BB1F8
2CIUSERARG _bfu_java 0xF12B7914
2CIUSERARG _org.apache.harmony.vmi.portlib 0x301A2E60
please help me in resolving this issue.
Re: Eclipse crash on AIX [message #1690645 is a reply to message #1690552] Mon, 30 March 2015 07:25 Go to previous message
Are you sure you picked the right forum?
Tom
> libraries. the required GTK libraries are already installed -
> mtools-3.9.7-4
> info-4.6-1
> zip-2.3-3
> gzip-1.4-1
> unzip-5.51-1
> cairo-1.10.0-1
> zlib-1.2.7-1
> expat-2.0.1-2
> freetype2-2.3.9-1
> fontconfig-2.4.2-1
> atk-1.12.3-2
> libpng-1.2.32-2
> glib2-2.14.6-2
> gettext-0.10.40-8
> libtiff-3.8.2-1
> AIX-rpm-7.1.3.0-12
> libjpeg-6b-6
> xrender-0.9.1-3
> xft-2.1.6-5
> pango-1.14.5-4
> xcursor-1.1.7-3
> pixman-0.20.0-1
> gtk2-2.10.6-5
> vnc-3.3.3r2-6
> JRE 7.0.7001
> 1TISIGINFO Dump Event "gpf" (00002000) received 1TIDATETIME
> NULL
> NULL 1XHEXCPCODE J9Generic_Signal_Number: 00000004
> NULL NULL 1XHREGISTERS Registers:
> NULL NULL
> 1CICMDLINE
> --launcher.library
> -startup
> 2CIUSERARG
> 2CIUSERARG
> 2CIUSERARG
> 2CIUSERARG
> 2CIUSERARG
> 2CIUSERARG
> 2CIUSERARG
> 2CIUSERARG
> 2CIUSERARG
> 2CIUSERARG -Xms40m
> 2CIUSERARG -Xmx512m
> 2CIUSERARG
> 2CIUSERARG
> --launcher.library
> -startup
Previous Topic:Getting rid of javax.annotation imports
Next Topic:current version of svg2fxml and where to find it
Current Time: Sat Jul 19 15:32:27 EDT 2025
Powered by FUDForum. Page generated in 0.03527 seconds
