Home » Modeling » TMF (Xtext) » Logical expressions within XExpressionOrVarDeclaration
Logical expressions within XExpressionOrVarDeclaration [message #1690364] Thu, 26 March 2015 17:58 Go to next message
Hello all,
Can someone tell me how to include logical and arithmetic expressions within XExpressionOrVarDeclaration and generate code for them?
I get the following kind of error: The method ==(int) is undefined
Thanks a lot
Re: Logical expressions within XExpressionOrVarDeclaration [message #1690396 is a reply to message #1690364] Fri, 27 March 2015 02:38 Go to previous messageGo to next message
can you elaborate what you are actually doing? the operators == >= <= > < are already defined in xbase and are implemented by the xbase libary. so simply add this one to the classpath of the project that contains your model file (org.eclipse.xtext.xbase.lib)
Re: Logical expressions within XExpressionOrVarDeclaration [message #1690423 is a reply to message #1690396] Fri, 27 March 2015 05:27 Go to previous messageGo to next message
I want to write simple Boolean expressions such as : x == y && y > 10
In my grammar, I have tried the followings:
Condition returns XBlockExpression:
{Condition}
(expressions += XAndExpression)*
But this does not compile. we get the error "The method &&(boolean) is not defined".
We used normal XExpression and XExpressionOrVarDeclaration but get the same error.
How can we get a logical expression to parse, and generate Java code from it?
Re: Logical expressions within XExpressionOrVarDeclaration [message #1690424 is a reply to message #1690423] Fri, 27 March 2015 05:31 Go to previous messageGo to next message
Just to mention that if I use XExpressionOrVarDeclaration, and I try to write an "If" statement in my language, I cannot write a boolean expression as "if" condition. So, something is not working....
Re: Logical expressions within XExpressionOrVarDeclaration [message #1690425 is a reply to message #1690424] Fri, 27 March 2015 05:34 Go to previous messageGo to next message
did you add the lib to the deps?
Re: Logical expressions within XExpressionOrVarDeclaration [message #1690431 is a reply to message #1690425] Fri, 27 March 2015 06:04 Go to previous messageGo to next message
Thanks, I added the libraries, so by having XExpressionOrVarDeclaration, I can write Boolean expressions.
However, what I actually want is when *defining* a method to have a boolean expression in its signature. Something like
op method(x>10&&y<10) {...}
How can we get this? In my grammar, I get the error that such expression is not allowed because it does not have side effects.
Re: Logical expressions within XExpressionOrVarDeclaration [message #1690432 is a reply to message #1690431] Fri, 27 March 2015 06:09 Go to previous messageGo to next message
what is the semantics of such an expression? maybe the same as here? https://www.eclipse.org/forums/index.php/t/1065012/
Re: Logical expressions within XExpressionOrVarDeclaration [message #1690433 is a reply to message #1690432] Fri, 27 March 2015 06:11 Go to previous messageGo to next message
The semantics is that the method can only be executed if the Boolean expression evaluates to the true.
Re: Logical expressions within XExpressionOrVarDeclaration [message #1690437 is a reply to message #1690433] Fri, 27 March 2015 06:23 Go to previous message
So it is the same semantics
Previous Topic:Code generator for Smalljava example
Next Topic:Leading whitespaces in template
Current Time: Sat Jul 19 23:46:49 EDT 2025
Powered by FUDForum. Page generated in 0.09678 seconds
