Home » Eclipse Projects » GEF » PropertySource
PropertySource [message #169013] Mon, 21 February 2005 04:50 Go to next message
Originally posted by: seb01016.fh-hagenber.at
Hello!
I use EMF and GEF in combination to create my own editor. I have added
serveral Property Sources that implement IPropertySource. So I can see the
properties in the default property view. If I use code generation
mechanism of EMF it generates classes (some Adapters in EMF.Edit) which
create entries in the property sheet too. I am interested in the editor
for collections. It offers a property entry, that has a button, which
opens a dialog, where the property values can be edited.
So my question is, how can i create such a PropertyDescriptor. It sould
allow a simple string, which sould not be editable and on the right hand
side a button, where I am able to open a dialog where I can edit the value
of the property.
Hopefully you can understand what I want to achieve.
thx in advance
Hannes
Re: PropertySource [message #169029 is a reply to message #169013] Mon, 21 February 2005 08:24 Go to previous messageGo to next message
Originally posted by: seb01016.fh-hag.at
Hi!
I have already found the solution. (Used my own PropertyDescriptor, that
uses a DialogCellEditor)
thx
Schoenboeck wrote:
> Hello!
> of the property.
> thx in advance
> Hannes
Re: PropertySource [message #169093 is a reply to message #169029] Mon, 21 February 2005 11:03 Go to previous message
Can't you just reused EMF.Edit's celleditor?
"Schoenboeck" <seb01016@fh-hag.at> escreveu na mensagem
news:cvcndi$jls$1@www.eclipse.org...
> Hi!
> thx
> Schoenboeck wrote:
>> Hello!
>> the properties in the default property view. If I use code generation
>> value of the property.
>> thx in advance
>> Hannes
Previous Topic:MVC or PAC
Next Topic:custom UpdateManager in Layer
Current Time: Sat Jul 19 08:00:32 EDT 2025
Powered by FUDForum. Page generated in 0.07304 seconds
