Home » Archived » Jubula » Configuring Jubula to launch using a Eclipse Debug Configuration(Trying to test Eclipse Application while developing in Eclipse)
Configuring Jubula to launch using a Eclipse Debug Configuration [message #1690220] Wed, 25 March 2015 14:44 Go to next message
Ok here goes at trying to describe this. I have searched and not found any answers.
Running Jubula Standalone
1) Start up Eclipse IDE
2) Download Source for product.
3) Build Source
4) Configure Eclipse Debug Launch Configuration to debug application.
5) How do I configure the AUT to start based on #4 ?
Or is there a better way to do this.
Re: Configuring Jubula to launch using a Eclipse Debug Configuration [message #1690257 is a reply to message #1690220] Thu, 26 March 2015 03:48 Go to previous messageGo to next message
Hi Jeff,
There are launch configurations available for Jubula, which are documented in the user manual. The launch configuration features are also installed with the standalone if I remember correctly. The documentation should provide you with the steps you need to be able to start your AUT via the Eclipse IDE. If you get stuck or if I've misunderstood you, let me know.
Alex
Re: Configuring Jubula to launch using a Eclipse Debug Configuration [message #1732996 is a reply to message #1690257] Mon, 23 May 2016 11:54 Go to previous messageGo to next message
Alex,
I am using MARS 3.2
I have read the manual 3.37 on configuring launch configurations and I am still stuck.
I have installed Jubula from the Eclipse Marketplace.
The manual 3.37.2 requires Jubula Launch Support , however I can not find any specific Jubula Launch in Debug Configuration ?
Re: Configuring Jubula to launch using a Eclipse Debug Configuration [message #1733056 is a reply to message #1732996] Tue, 24 May 2016 02:07 Go to previous message
Hi Jeff,
If you've installed Jubula from the marketplace, then you'll also need the Jubula Launch Support Feature from the Marketplace - if you have installed that and it still isn't working, let me know.
Alex
Previous Topic:AUT Agent standalone
Next Topic:Jubula Demo with HTML
Current Time: Sun Jul 20 10:52:16 EDT 2025
Powered by FUDForum. Page generated in 0.03086 seconds
