Home » Modeling » EMF » Use spaces instead of tab in generated code [solved]
Use spaces instead of tab in generated code [solved] [message #1689583] Mon, 23 March 2015 17:56 Go to next message
I have a project created using EMF 2.9.2 where everything was working fine. Today I migrated it to EMF 2.10.1, and found the newly generated code uses tab indentation in many places (e.g. comments) instead of spaces. How can I fix this?
Note that I have already set my Preferences->Java->Code Style->Formatter->Indentation->Tab policy = Spaces only
Turns out to be a bug in Java Formatter Importer, that my imported change is not picked up until I manually change something and save it.
[Updated on: Mon, 23 March 2015 18:20] by Moderator
Re: Use spaces instead of tab in generated code comments [message #1689729 is a reply to message #1689583] Tue, 24 March 2015 03:42 Go to previous messageGo to next message
Jimmy,
Do you have the GenModel's Code Formatting property set to true and the
Comment Formatting set to false? If Code Formatting is set to true,
JDT should do the formatting, if it's set false, it should use the
preference's setting:
String tabCharacter =
options.get(DefaultCodeFormatterConstants.FORMATTER_TAB_CHAR);
if (JavaCore.TAB.equals(tabCharacter))
jControlModel.setLeadingTabReplacement("\t");
else
String spaces = "";
for (int i = Integer.parseInt(tabSize); i > 0; --i)
spaces += " ";
jControlModel.setLeadingTabReplacement(spaces);
Note that once it's messed up in the workspace, regenerating might not
fix it until you discard the local changes.
> generated code uses tab to indent the comments instead of spaces. How
> can I fix this?
Re: Use spaces instead of tab in generated code comments [message #1690191 is a reply to message #1689729] Wed, 25 March 2015 11:33 Go to previous message
Thank you for the help I resolved the problem. My
Code Formatting = false
Comment Formatting = false
And it should have picked up the settings in my preferences, but it did not until I change and save the preferences. I guess this is a minor bug here.
Ed Merks wrote on Tue, 24 March 2015 07:42
Jimmy,
else
String spaces = "";
spaces += " ";
Previous Topic:Current Release Version of CDO
Next Topic:EMF : Error loading XMI file
Current Time: Sat Jul 19 20:03:26 EDT 2025
Powered by FUDForum. Page generated in 0.25518 seconds
