Home » Modeling » Model-to-Model Transformation » QVTo constructor behavior when extending transformations
QVTo constructor behavior when extending transformations [message #1688375] Fri, 20 March 2015 11:20 Go to next message
I observed the following behavior for constructors, which I didn't expect:
I have two transformations A, and B. B extends A. A contains a constructor (ConsA). A also contains a mapping which uses ConsA (mappingA). I intended to overwrite this constructor in B and hence added a new implementation of ConsA in B. B utilizes mappingA. Much to my surprise the constructor from A is called rather from B. If I surround the constructor in a mapping which I also overwrite in transformation B the new constructor is used.
In pseudo code:
transformation A();
mapping mappingA()
 new ConsA();
ConsA::ConsA(inp:String) // The to be created object is named ConsA for this example.
 log("Constructor from mapping A");
transformation B() extends transformation A();
mapping X()
 map mappingA();
ConsA::ConsA(inp:String) // The to be created typeis named ConsA for this example.
  log("Constructor from mapping B");
Logs: Constructor from mapping A.
Overwriting mappingA in transformation B will result in: Constructor from mapping B.
The QVTo spec states:
1) A constructor may be defined as an operation of the class to be constructed or may be owned by a module that plays a role of factory for the class.
2) An access import behaves as a traditional package import, whereas extension semantics combines package import and class inheritance paradigm.
Is the current behavior correct? Can I make my constructor be owned by the class rather than the module?
Kind regards,
Teun
Re: QVTo constructor behavior when extending transformations [message #1688390 is a reply to message #1688375] Fri, 20 March 2015 11:45 Go to previous messageGo to next message
Please use the qvto newsgroup for QVTo discussions.
In this case please raise a Bugzilla.
Ed Willink
On 20/03/2015 15:20, Teun van de Berg wrote:
> expect:
> In pseudo code:
> transformation A();
> mapping mappingA()
> new ConsA();
> for this example.
> mapping X()
> map mappingA();
> this example.
> from mapping B.
> Quote:
>> for the class. 2) An access import behaves as a traditional package
> Kind regards,
> Teun
Re: QVTo constructor behavior when extending transformations [message #1689357 is a reply to message #1688390] Mon, 23 March 2015 07:47 Go to previous message
Thanks for your confirmation that this is a bug. I'll open a Bugzilla.
Teun
Previous Topic:many to one mapping
Next Topic:Transforming Ecore diagrams with mediniQVT
Current Time: Sun Jul 20 06:18:50 EDT 2025
Powered by FUDForum. Page generated in 0.03879 seconds
