Home » Modeling » TMF (Xtext) » org.eclipse.core.contenttype.contentTypes support
org.eclipse.core.contenttype.contentTypes support [message #1688295] Fri, 20 March 2015 08:43 Go to next message
I've finally identified why my Xtext editors have an irritating log
message (Bug 453669) when saved, whereas the Xtext Xtext editor does not.
The difference appears to be that Xtext editors used to use the
org.eclipse.core.contenttype.contentTypes extension point but don't any
longer. My editors still do.
The problem seems to arise because an Xtext source may be either ASCII
text as seen in the editor, or an EMF model. Thus when
FileDocumentProvider.getCharsetForNewFile prepares for save, the
RootXMLContentHandlerImpl.contentDescription uses
URIConverter$ReadableInputStream.read which throws an NPE when
attempting to use the null encoding 'identified' in a non-XML file.
Failure to support org.eclipse.core.contenttype.contentTypes seems like
a retrograde step. Is this intentional, or should I raise a Bugzilla
suggesting that an XtextContentHandlerImpl override of
RootXMLContentHandlerImpl is needed to support the dual source file
representation that Xtext facilitates?
Ed Willink
Re: org.eclipse.core.contenttype.contentTypes support [message #1688351 is a reply to message #1688295] Fri, 20 March 2015 10:17 Go to previous message
Correction: the problematic org.eclipse.core.contenttype.contentTypes
support only arises if the (manual) genmodel contains a non-blank
contentTypeIdentifier. i.e. a self-inflicted problem invoking an
unsupported combination of functionalities.
Ed Willink
On 20/03/2015 12:43, Ed Willink wrote:
> Hi
> any longer. My editors still do.
> like a retrograde step. Is this intentional, or should I raise a
> Bugzilla suggesting that an XtextContentHandlerImpl override of
> Regards
> Ed Willink
Previous Topic:CrossReferences [..|STRING] and AutoEditing is not nice
Next Topic:Serialization issues
Current Time: Sat Jul 19 11:42:54 EDT 2025
Powered by FUDForum. Page generated in 0.04165 seconds
