Home » Language IDEs » PHP Development Tools (PDT) » The formatter joins multiline string on a single line
The formatter joins multiline string on a single line [message #1687681] Thu, 19 March 2015 15:05 Go to next message
Eclipse for PHP Developers
Version: Luna Service Release 2 (4.4.2)
Build id: 20150219-0600
When I have something like
$a = "aaaaaaaaaaaaaaaaaaaaaaaaa".
     "bbbbbbbbbbbbbbbbbbbb";
using CTR+SHIF+F results in
$a = "aaaaaaaaaaaaaaaaaaaaaaaaa" . "bbbbbbbbbbbbbbbbbbbb";
Imagine what happens to a long sql statement splitted in a proper way using ctrl+shif+f !!! Evil or Very Mad
I've already taken a look at every option in
preferences->php->code style->formatter
and
preferences->php->editor
and
preferences->General->editors
... but no luck.
hope there is an option other then @formatter:off Confused
Thanks in advance,
Rik
[Updated on: Thu, 19 March 2015 16:31] by Moderator
Re: The formatter joins multiline string on a single line [message #1688279 is a reply to message #1687681] Fri, 20 March 2015 08:13 Go to previous messageGo to next message
No, now it's not possible to preserve new lines between operators.
Re: The formatter joins multiline string on a single line [message #1688349 is a reply to message #1688279] Fri, 20 March 2015 10:17 Go to previous messageGo to next message
OH MY GOSH! It's incredible!
For every string I have to set on and off the format option?! Shocked
What is the criterion used by the decision makers of this "feature"?
What's for, a formatter that change this
$stm = 'CREATE TABLE queue(' .
   'id INTEGER PRIMARY KEY,' .
   'rec TEXT NOT NULL,' .
   'subject TEXT NOT NULL,' .
   'body TEXT NOT NULL,' .
   'headers TEXT NOT NULL);';
into a single line that need horizontal scroll? (Not in this forum because it's more intelligent than Eclipse)?
$stm = 'CREATE TABLE queue(' . 'id INTEGER PRIMARY KEY,' . 'rec TEXT NOT NULL,' . 'subject TEXT NOT NULL,' . 'body TEXT NOT NULL,' . 'headers TEXT NOT NULL);'
I can't do it. I give up.
Do you know a previous version without this problem?
Keplero? Juno? Or I'd better to restore the Indigo version I was using before this bad attemp with Luna?
Re: The formatter joins multiline string on a single line [message #1688352 is a reply to message #1688349] Fri, 20 March 2015 10:20 Go to previous messageGo to next message
PS: I suggest to add the option: "Please, don't touch my string!" Very Happy
It will be very appreciated (and will avoid many migrations to Netbeans).
Re: The formatter joins multiline string on a single line [message #1688367 is a reply to message #1688352] Fri, 20 March 2015 10:54 Go to previous messageGo to next message
Netbeans haven't as advanced formatter as we now Wink
Two options should fix your problem:
1. Initializer justification
2. Preserve new lines after "." operator
$x = "sdfsdf" .
"sdfsdfsdfsdf" .
"sf";
You can prepare enhancement request on bugzilla. If not I'll do it later.
Re: The formatter joins multiline string on a single line [message #1688407 is a reply to message #1688367] Fri, 20 March 2015 12:45 Go to previous messageGo to next message
Yes I know, but in a way, too much advanced could be harmful if its beyond certain limits and becomes annoying! Razz
It's a bit like the linux distros: Ubuntu+Unity it's surely modern and advanced, but just for this reason Ubuntu is now number 2 and Mint Mate is the nr 1.
For me, indigo+PDT was already the top.
I didn't need anything more.
Unfortunately once per decade it's necessary to upgrade (e.g. new php features not supported) and that's why I'm here with Luna... but I knew in advance that this migration it would be full of complications and basically nothing better because I didn't need another formatter, GTK graphics, etc.... by the way: gtk theme on Mint + NVidia sucks: when I try to move tabs it flicker both monitor and every windows. I've found a solution and I reported on my wiki
Eclipse Luna speed up and fix flickering
OK, I'm going to try this solution first.
Thanks for you mega-help in any case.
Re: The formatter joins multiline string on a single line [message #1688411 is a reply to message #1688407] Fri, 20 March 2015 12:55 Go to previous messageGo to next message
Ehm... I don't even find those options. I exported everything in xml to search the key words in a text editor, but I don't find them.
Is it in the PHP formatter or somewhere else? I continue to search...
Re: The formatter joins multiline string on a single line [message #1688416 is a reply to message #1688411] Fri, 20 March 2015 13:07 Go to previous messageGo to next message
Uhm... maybe I misunderstood and
is what I have to ask as enhancement request on bugzilla? Rolling Eyes
Re: The formatter joins multiline string on a single line [message #1688420 is a reply to message #1688416] Fri, 20 March 2015 13:16 Go to previous messageGo to next message
Hmm something like: "Improve string concat formatting" + example in description should be enough Wink
Re: The formatter joins multiline string on a single line [message #1688423 is a reply to message #1688420] Fri, 20 March 2015 13:23 Go to previous messageGo to next message
I didn't understand if
is something already existing or is what I have to ask for.
Re: The formatter joins multiline string on a single line [message #1688424 is a reply to message #1688423] Fri, 20 March 2015 13:24 Go to previous messageGo to next message
This is a potential way how this could be implemented. Ignore this Wink
Re: The formatter joins multiline string on a single line [message #1688427 is a reply to message #1688424] Fri, 20 March 2015 13:27 Go to previous messageGo to next message
Ah ok. Have you any idea how many centuries it will take to be realised?
Re: The formatter joins multiline string on a single line [message #1688430 is a reply to message #1688427] Fri, 20 March 2015 13:35 Go to previous messageGo to next message
... and any chance for a workaround (in the meantime) to have the PHP code formatter behaving like the HTML one, wrapping the strings in a way I don't have to scroll horizontally?
Re: The formatter joins multiline string on a single line [message #1688455 is a reply to message #1688430] Fri, 20 March 2015 14:44 Go to previous messageGo to next message
Bug report created
https://bugs.eclipse.org/bugs/show_bug.cgi?id=462711
Re: The formatter joins multiline string on a single line [message #1688665 is a reply to message #1688455] Sat, 21 March 2015 06:13 Go to previous message
Any workaround to remove completely the format rules on the code, but the indentation?
I actually prefer no code formatting except the indentation that helps when I loose manual control and there is a } that don't mach something.
Just as it was PDT 3.1
[Updated on: Sat, 21 March 2015 06:18] by Moderator
Previous Topic:Tasklist with TODO in code not working
Next Topic:Need help taking and displaying multiple photos on the same layout
Current Time: Sun Jul 20 16:39:06 EDT 2025
Powered by FUDForum. Page generated in 0.06154 seconds
