Home » Modeling » Papyrus » Update site times out?
Update site times out? [message #1649077] Wed, 04 March 2015 01:27 Go to next message
Anybody else experiencing problems with the Luna update site?
I get first 2% and then 10% of something, then it just times out.
Trying to add Papyrus to Eclipse SR2, but without the update site thing might be difficult...
Tomas Sandkvist
Re: Update site times out? [message #1649160 is a reply to message #1649077] Wed, 04 March 2015 02:21 Go to previous messageGo to next message
I have experienced the same problem myself. I cannot add Papyrus SR2 to Eclipse SR2.
Re: Update site times out? [message #1649313 is a reply to message #1649160] Wed, 04 March 2015 04:02 Go to previous messageGo to next message
There are indeed some issues with the Eclipse update sites. Lots of read time out and slow download speeds. AFAIK, it is not related to Papyrus
Camille
Re: Update site times out? [message #1683756 is a reply to message #1649313] Wed, 18 March 2015 02:31 Go to previous messageGo to next message
Camille Letavernier wrote on Wed, 04 March 2015 04:02
Camille
Hi Camille!
Found this conversation http://comments.gmane.org/gmane.comp.ide.eclipse.cross.project/4939
but nothing more said after March 6, can you shed some light on this? Tried to install Papyrus SR2 as of today, but the update site still times out.
I can probably live without SR2, but if the same problem arises with Mars release... no fun...
I know this is not a Papyrus problem, but I don't know where else to put these question(s)?
Tomas
Re: Update site times out? [message #1684014 is a reply to message #1683756] Wed, 18 March 2015 04:48 Go to previous messageGo to next message
Hi Tomas,
You can download the Zip version of the update site for Papyrus 1.0.2:
https://www.eclipse.org/papyrus/downloads/
Dependencies (and extra-plugins) will still need to be downloaded online, but at least this should help
Camille
Re: Update site times out? [message #1686377 is a reply to message #1684014] Thu, 19 March 2015 02:52 Go to previous messageGo to next message
Camille Letavernier wrote on Wed, 18 March 2015 04:48
Hi Tomas,
Camille
Hi Camille!
While downloading the zip file was possible (but not from all the listed sites though), the installation stalls at stage 2 (it first took an eternity to get there) with the text "Cannot perform operation. Computing alternate solutions, may take a while. It probably takes more than that, after 5 minutes I gave up waiting...
This was the resulting message>
Cannot complete the install because one or more required items could not be found.
Software being installed: Papyrus UML 1.0.2.v201502181349 (org.eclipse.papyrus.sdk.feature.feature.group 1.0.2.v201502181349)
Missing requirement: Papyrus properties generation 1.0.2.v201502181349 (org.eclipse.papyrus.customization.properties.generation 1.0.2.v201502181349) requires 'bundle org.eclipse.m2m.qvt.oml 3.0.1' but it could not be found
Cannot satisfy dependency:
From: Papyrus customization 1.0.2.v201502181349 (org.eclipse.papyrus.customization.feature.feature.group 1.0.2.v201502181349)
To: org.eclipse.papyrus.customization.properties.generation [1.0.2.v201502181349]
From: Papyrus UML 1.0.2.v201502181349 (org.eclipse.papyrus.sdk.feature.feature.group 1.0.2.v201502181349)
To: org.eclipse.papyrus.customization.feature.feature.group [1.0.2.v201502181349]
Tomas
[Updated on: Thu, 19 March 2015 02:53] by Moderator
Re: Update site times out? [message #1686780 is a reply to message #1686377] Thu, 19 March 2015 06:45 Go to previous messageGo to next message
You usually don't want to know the solutions. Just cancel and it will
show you the problem that you can then fix.
(Bug 462545 raised to provide this feedback automatically.)
Ed Willink
>> Hi Tomas,
>> Camille
> Hi Camille!
> Regards,
> Tomas
Re: Update site times out? [message #1689831 is a reply to message #1686780] Tue, 24 March 2015 08:38 Go to previous messageGo to next message
No Message Body
[Updated on: Tue, 24 March 2015 08:38] by Moderator
Re: Update site times out? [message #1690077 is a reply to message #1686780] Wed, 25 March 2015 01:47 Go to previous messageGo to next message
Today I tried around for other Eclipse update sites and found no-one to work!
After some googling I found that the culprit was the proxy settings of my computer. On my previous computer the setting was (and had been for many years in my company) manual proxy selection. But on this new computer the IT department had set it to automatic detection.
After setting the proxy to manual SR2 Papyrus installation works!
So, it appears I have cried Wolf when there was none....my sincerest apologies for this.
Tomas
[Updated on: Wed, 25 March 2015 02:19] by Moderator
Re: Update site times out? [message #1690091 is a reply to message #1690077] Wed, 25 March 2015 04:35 Go to previous messageGo to next message
Hi Tomas,
That's really surprising. I've been able to make several different installations on different versions of Eclipse/Papyrus recently. It definitely takes more time than usual (To load the update site initially, and then to download the components), but it still works in the end. And Eclipse has a cache for downloaded artifacts, so even if something times out, the next attempt should start where the previous failed.
Which update sites are you using, and from which Eclipse package?
Camille
Re: Update site times out? [message #1690247 is a reply to message #1690091] Thu, 26 March 2015 02:02 Go to previous messageGo to next message
Hi Camille!
I have tried (from Eclipse SR2 32-bit):
- http://download.eclipse.org/modeling/mdt/papyrus/updates/releases/luna
- http://download.eclipse.org/modeling/mdt/bpmn2/updates/milestones/S20130822/
- http://download.eclipse.org/eclipse/updates/4.4
all respond the same with proxy set to automatic (i.e. all the selections available from start or those I have added myself). This morning I also noted that if I return the setting to auto without rebooting my computer, the sites seems to communicate properly with my PC. After I reboot (with proxy auto), the timeout returns.
I have actually seen a similar problem with auto proxy when moving my computer from the office to home. So, question is, related to the company network or how sites communicate? I have no clue, this is beyond my understanding... So, as far from Papyrus issues as you could get, but still intriguing...
Tomas
Re: Update site times out? [message #1728786 is a reply to message #1690247] Thu, 07 April 2016 07:30 Go to previous message
this problem not only with Eclipse/Papyrus ... im agree with Camille u should use ZIP version
[Updated on: Tue, 03 May 2016 14:53] by Moderator
Previous Topic:Creating an attribute stereotype
Next Topic:SysML State Machine Problem
Current Time: Sat Jul 19 13:40:38 EDT 2025
Powered by FUDForum. Page generated in 0.05192 seconds
