Home » Newcomers » Newcomers » Eclipse directory problem
Eclipse directory problem [message #168636] |
Thu, 31 August 2006 08:44  |
I'm having a problem getting eclipse set up to my new environment. They
have been using ant build files and have all of their source files in src/
and their tests in test/. When I check these out from source control to
create a new java project, it won't recognize the package names because
eclipse thinks the package name should be src.com.acs... instead of
com.acs...
Is there a way I can convince harvest to use the package specified instead
of creating its own from the directory structure?
Thanks.
Re: Eclipse directory problem [message #168952 is a reply to message #168904] |
Fri, 01 September 2006 10:18   |
Originally posted by: wegener.cboenospam.com
Wes Harrison wrote:
> "Dave Wegener" <wegener@cboenospam.com> wrote in message
> news:9bbeb2c3fa022752aeba3207a707d2b2$1@www.eclipse.org...
>>> news:8b865d13816cb2f455c642ac69e3c1ab$1@www.eclipse.org...
>>>>> src/ and their tests in test/. When I check these out from source
>>>>> control to create a new java project, it won't recognize the package
>>>>> names because eclipse thinks the package name should be src.com.acs...
>>>>> instead of com.acs...
>>>>> instead of creating its own from the directory structure?
>>>>> Thanks.
>>>> On the Java Build Path properties page, go to the Source tab. Click on
>>>> Add Folder. The resulting dialog should show the src and test folders.
>>>> Check each one and hit OK.
>>>> You may also want/need to change the default output folder.
>>> I also use the src/ for all source, build/ for compiler output and test/
>>> for all tests but I see nothing that refers to "Test"
>>> folders/directories, only "Source" in this tab. When I click on Add
>>> Folder all I get is a window which allows me to select a source folder,
>>> not a test folder. Does Eclipse treat them the same? Is my project
>>> missing something wrt to JUnit?
>>> Thanks,
>>> Wes
>> The Source tab refers to all directories that contain Java source code
>> that needs to be compiled. Since JUnit tests are Java source that must be
>> compiled before they can be run, they need to be defined on the Source
>> tab.
> But this only allows for a test/ directory _under_ src/. I want to have
> test/ at the same level as src/ and build/. Is this something that just
> can't be done with Eclipse?
> Wes
Your description indicates a project layout as follows:
project_root/
src/
test/
build/
In this case, both src/ and test/ should be added as source folders on the
Source tab. Click on Add folder and check both of them in the dialog. At
the bottom of the Source tab, enter build/ as the output folder.
Re: Eclipse directory problem [message #169310 is a reply to message #169236] |
Mon, 04 September 2006 15:12   |
Wes Harrison wrote:
> "Eric Rizzo" <eclipse4@rizzoweb.com> wrote in message
> news:edg7r9$s0k$2@utils.eclipse.org...
>>>>> be compiled before they can be run, they need to be defined on the
>>>>> Source tab.
>>>> Thanks,
>>>> Wes
>>> project_root/
>>> src/
>>> test/
>>> build/
>>> the Source tab. Click on Add folder and check both of them in the
>>> dialog. At the bottom of the Source tab, enter build/ as the output
>>> folder.
>> In addition to Dave's patient help, I will strongly suggest opening the
>> Eclipse Help Contents and going through all the Getting Started sections,
>> especially under Java Development User Guide and Workbench User Guide. The
>> tutorials there will help you a great deal and would have avoided the need
>> for this entire thread.
>> Hope this helps,
> No, it didn't. May I politely suggest you keep your RTFMs to yourself? The
> problem I was having was caused by creating the project root directory in
> the source directory so every created folder would appear under src/. I
> have read all the relevant tutorials and documentation and simply made a
> mistake. You may not be familiar with mistakes as you clearly don't make
> them. May I also further suggest that if reading a thread where someone who
> has just picked up a new product makes a mistake is so irritating then
> perhaps you should avoid usenet altogether because it is actualy quite a
> common thing.
> Wes
I just want to confirm that have resolved your issue by changing the
project root directory. If so, does this work for your needs?
Re: Eclipse directory problem [message #169342 is a reply to message #169310] |
Mon, 04 September 2006 18:49   |
Originally posted by: nospam.home.com
"David Wegener" <wegener@cboenospam.com> wrote in message
news:edhtrb$l88$1@utils.eclipse.org...
>>> Dave Wegener wrote:
>>>>>> code that needs to be compiled. Since JUnit tests are Java source
>>>>>> that must be compiled before they can be run, they need to be defined
>>>>>> on the Source tab.
>>>>> have test/ at the same level as src/ and build/. Is this something
>>>>> that just can't be done with Eclipse?
>>>>> Thanks,
>>>>> Wes
>>>> project_root/
>>>> src/
>>>> test/
>>>> build/
>>>> folder.
>>> sections, especially under Java Development User Guide and Workbench
>>> User Guide. The tutorials there will help you a great deal and would
>>> have avoided the need for this entire thread.
>>> Hope this helps,
>> The problem I was having was caused by creating the project root
>> directory in the source directory so every created folder would appear
>> under src/. I have read all the relevant tutorials and documentation and
>> simply made a mistake. You may not be familiar with mistakes as you
>> clearly don't make them. May I also further suggest that if reading a
>> thread where someone who has just picked up a new product makes a mistake
>> is so irritating then perhaps you should avoid usenet altogether because
>> it is actualy quite a common thing.
>> Wes
Yes, it's working now that I have recreated the project with the correct
root directory. Thanks for your help.
Wes
Re: Eclipse directory problem [message #169386 is a reply to message #169236] |
Tue, 05 September 2006 00:13   |
>> Hope this helps,
> common thing.
Hey newbie, check the bad attitude at the door. Eclipse newsgroups are a
friendly place and don't need that kind of crap.
I don't see where in my message there was any insulting material, so
I'll kindly ask you to read it again to make sure it was not
misinterpreted. In particular, at no point did I say anyone was
irritated by your question or that I don't make mistakes. I, in fact,
have a lengthy Usenet history that can be verified by anyone and Google,
so your comments are particularly insulting.
My reputation around here certainly excuses me from having to justify a
friendly reminder about the tutorials - it is something I point out to
many newbies every week, and I always do so with a gentle touch after
practical advice or help has been provided.
It is too bad you misinterpreted my message, because I always like to
help people and exchange knowledge - a relationship you and I are
unlikely to enjoy now that you've hurled insults and blatant ingratitude.
Eric
Re: Eclipse directory problem [message #169510 is a reply to message #169386] |
Tue, 05 September 2006 08:48   |
news:edit7i$cnu$1@utils.eclipse.org...
>>> Hope this helps,
> I don't see where in my message there was any insulting material, so I'll
> kindly ask you to read it again to make sure it was not misinterpreted. In
> particular, at no point did I say anyone was irritated by your question or
> that I don't make mistakes. I, in fact, have a lengthy Usenet history that
> can be verified by anyone and Google, so your comments are particularly
> insulting.
> It is too bad you misinterpreted my message, because I always like to help
> people and exchange knowledge - a relationship you and I are unlikely to
I have just come from a NetBeans support environment where I have never been
told that it requires patience to help me or that a thread should never have
been started had I RTFM. I was merely pointing out that newbies exist with
every product and if it is so painful for you to read my posts then perhaps
you are looking in the wrong newsgroup.
Wes
Re: Eclipse directory problem [message #169576 is a reply to message #169510] |
Tue, 05 September 2006 10:45  |
[snip]
> Wes
Please stop putting words in my mouth.
Current Time: Sat Jul 19 14:49:43 EDT 2025
Powered by FUDForum. Page generated in 0.09130 seconds
