Home » Eclipse Projects » GEF » displaying graph in popup window
displaying graph in popup window [message #168557] Wed, 16 February 2005 12:29 Go to next message
Hi -- I'm trying to display a graphical editor in a popup window (shell),
but am not seeing its graph when I do a shell.open(). Has anyone tried to
do this? Any help would be greatly appreciated.
Thanks -- james barnett
Re: displaying graph in popup window [message #168585 is a reply to message #168557] Wed, 16 February 2005 16:22 Go to previous messageGo to next message
did you position the Canvas? Layout?
"James Barnett" <jbarnett@bea.com> escreveu na mensagem
news:cuvvtq$8ej$1@www.eclipse.org...
Re: displaying graph in popup window [message #168601 is a reply to message #168585] Wed, 16 February 2005 23:05 Go to previous message
I had got a Graphical viewer embedded in a dialog.
Hopefully it should be the same for a shell as well.
The following are the basic things that need to be done
//instantiate the viewer
ScrollingGraphicalViewer graphicalViewer = new ScrollingGraphicalViewer();
//Create the control
Control control = graphicalViewer.createControl(parentComposite);
//Set the edit Part factory
graphicalViewer.setEditPartFactory(new GraphicalEditPartsFactory());
//Set the root edit part
graphicalViewer.setRootEditPart(new FreeformGraphicalRootEditPart());
//Set the edit domain
graphicalViewer.setEditDomain(new DefaultEditDomain(null));
//set the command stack
graphicalViewer.getEditDomain().setCommandStack(new CommandStack());
I am guessing you should have done this.
If it doesn't shup up then you might need to check whether you have set
a layout for the parent composite.
Not setting the layout also causes the components to not display.
Roshan
Previous Topic:Cancel a time consuming paint operation
Next Topic:Need help in PolylineConnection
Current Time: Sat Jul 19 09:54:55 EDT 2025
Powered by FUDForum. Page generated in 0.03309 seconds
