Home » Eclipse Projects » GEF » My DirectEdit works only if I override the DirectEditManager.commit() method?!
My DirectEdit works only if I override the DirectEditManager.commit() method?! [message #167828] Fri, 11 February 2005 05:52 Go to next message
I have copy code snippets for direct edit a Label ....works fine.
(The code snippet has overriden the commit() method of DirectEditManager)
2.)
I have copy the code for the StickyNote in the digital-simulator example and the
new entered text of the direct edit will NOT transfer to my Model!
I always receive the old value!
protected Command <MyDirectEditPolicy>.getDirectEditCommand(DirectEditRequest request)
String labelText = (String)request.getCellEditor().getValue();
System.out.println("NEW VALUE:"+labelText);
// ERROR labelText is the old value!!!!!!!!!!!!!!!!!!!!
return cmd;
3.)
I override the commit() in MyDirectEditManager of the digital-simulator code snippet
and it work fine!
protected void <MyDirectEditManager>.commit()
if (committing)
return;
committing = true;
try
getCellEditor().getControl().setVisible(false);
if (isDirty())
CommandStack stack = getEditPart().getViewer().getEditDomain().getCommandStack();
Command command = getEditPart().getCommand(getDirectEditRequest());
if (command != null && command.canExecute())
stack.execute(command);
finally
bringDown();
committing = false;
Why works the DirectEdit in digitalSimulator and why must I override the
commit() method?!
greetings
Andreas
Re: My DirectEdit works only if I override the DirectEditManager.commit() method?! [message #168090 is a reply to message #167828] Sat, 12 February 2005 02:20 Go to previous messageGo to next message
Don't know what could be causing this. But the way it's done in the logic
example works there and elsewhere too. What code-base are you using?
The only difference I noticed between your commit() method and
DirectEditManager's is that you're invoking
getCellEditor().getControl().setVisible(false). Are you saying this is
what's making it work? What happens if you remove that line of code from
the overridden method?
"FreeGroup" <a.herz@FreeGroup.de> wrote in message
news:cui2tn$8le$1@www.eclipse.org...
> 1.)
> 2.)
and the
> protected Command
> return cmd;
> 3.)
code snippet
> and it work fine!
> if (committing)
> return;
> committing = true;
> try
> if (isDirty())
> finally
> bringDown();
> committing = false;
> commit() method?!
> greetings
> Andreas
Re: My DirectEdit works only if I override the DirectEditManager.commit() method?! [message #168163 is a reply to message #168090] Mon, 14 February 2005 01:36 Go to previous message
I have removed the line
and it works fine.
2.)
I have add the line
eraseFeedback()
and I have the problem. I always retrieve the old value
if the element!
I use eclipse 3.1 with GEF 3.0.1
greetings
Andreas
Previous Topic:Is it possible create Microsoft office like Palette?
Next Topic:how to get the location of an image in a label?
Current Time: Sun Jul 20 15:59:39 EDT 2025
Powered by FUDForum. Page generated in 0.04041 seconds
