Home » Eclipse Projects » GEF » Moving Figure, SHIFT or CTRL key is down
Moving Figure, SHIFT or CTRL key is down [message #167523] |
Wed, 09 February 2005 09:29  |
Originally posted by: jsk_lam.hotmail.com
On moving an figure object with the mouse, I need to test to see
if the SHIFT or CTRL key is pressed down , can someone show
me how to test it? Also, where or which notification method should
I look into for updating the information of the figure being moved?
SL
Re: Moving Figure, SHIFT or CTRL key is down [message #167538 is a reply to message #167523] |
Wed, 09 February 2005 09:43   |
public class CreationTool
extends TargetingTool
protected void updateTargetRequest() {
CreateRequest req = getCreateRequest();
if (isInState(STATE_DRAG_IN_PROGRESS)) {
Point loq = getStartLocation();
Rectangle bounds = new Rectangle(loq, loq);
bounds.union(loq.getTranslated(getDragMoveDelta()));
req.setSize(bounds.getSize());
req.setLocation(bounds.getLocation());
req.getExtendedData().clear();
if (!getCurrentInput().isAltKeyDown() && helper != null) {
PrecisionRectangle baseRect = new PrecisionRectangle(bounds);
PrecisionRectangle result = baseRect.getPreciseCopy();
helper.snapRectangle(req, PositionConstants.NSEW,
baseRect, result);
req.setLocation(result.getLocation());
req.setSize(result.getSize());
} else {
req.setSize(null);
req.setLocation(getLocation());
Mostly it depends in which class you want to check key state
"slam" <jsk_lam@hotmail.com> wrote in message
news:cud6n8$jim$1@www.eclipse.org...
> Thanks
> SL
Re: Moving Figure, SHIFT or CTRL key is down [message #167598 is a reply to message #167538] |
Wed, 09 February 2005 16:21   |
Well, what I need to do is when the user moves the figure,
I need to move all its child nodes along (only when the SHIFT
key is pressed). That is, I need to update all the child node's
location when the parent node is moved. How do I do it?
How to register or use the TargetingTool with the figure?
Thanls
SL
"b00lean" <kk@cleverlance.com> wrote in message
news:cud7jj$nqi$1@www.eclipse.org...
> baseRect, result);
> } else {
> req.setSize(null);
> > Hi,
> > Thanks
> > SL
Re: Moving Figure, SHIFT or CTRL key is down [message #167629 is a reply to message #167592] |
Wed, 09 February 2005 17:16   |
From your drag tracker, you can call getCurrentInput().isShiftKeyDown().
"slam" <jsk_lam@hotmail.com> escreveu na mensagem
news:cudutd$876$1@www.eclipse.org...
> Thanls
> SL
> "Randy Hudson" <none@us.ibm.com> wrote in message
> news:cudpas$ddj$1@www.eclipse.org...
>> This is already done for you. CTRL turns a drag into a "clone". Shift
>> restricts motion to 45 desgrees.
>> > Hi,
>> > Thanks
>> > SL
Re: Moving Figure, SHIFT or CTRL key is down [message #167697 is a reply to message #167629] |
Thu, 10 February 2005 01:45   |
Hi Randy,
How do I get the drag tracker notification?
SL
news:cue23s$m37$1@www.eclipse.org...
> > Thanls
> > SL
> >> > Hi,
> >> > Thanks
> >> > SL
Re: Moving Figure, SHIFT or CTRL key is down [message #167914 is a reply to message #167629] |
Fri, 11 February 2005 21:17   |
Hi Randy,
I am not using the Drag Tracker at all. Is there a way that I can found
out whether the SHIFT key is pressed (from any code)?
SL
> > Thanls
> > SL
> >> > Hi,
> >> > Thanks
> >> > SL
Re: Moving Figure, SHIFT or CTRL key is down [message #168036 is a reply to message #167914] |
Sun, 13 February 2005 20:15  |
So, you are using just draw2d? The mouse event should have as much
information in it as an SWT mouse event. Determining if the SHIFT key is
down is the same as it is in SWT. You could also just look at the code for
the method I pointed you to.
news:cujovr$ntv$1@www.eclipse.org...
> Hi Randy,
> Thanks
> SL
>> > Thanls
>> > SL
>> >> Shift
>> >> > Hi,
>> >> > Thanks
>> >> > SL
Current Time: Sat Jul 19 06:37:57 EDT 2025
Powered by FUDForum. Page generated in 0.04903 seconds
