Home » Language IDEs » Java Development Tools (JDT) » root variable path - where has it gone
root variable path - where has it gone [message #166989] Fri, 02 July 2004 09:55 Go to next message
Originally posted by: phil.meier.gmx.net
I want to set my Java Source Attachment (so I can step through my java
source code when using a library).
In Eclipse 2.0.x (WSDD 5.0) I had to supply a "Archive variable path"
and an "Root variable path". Like this I was able to define the root of
the package structure in the archive. For example root path = 'src' if
the archive contains src/java/lang/Object.java.
Since Eclipse 2.1.x (WSDD 5.6) I am missing this possibility. And also
in Eclipse 3.0 there is no possibility to set the "root variable path"
for my Java Source Attachment. I only have the possibility to set the
"Archive variable path". Where has it gone? Do I still have the
possibility to somehow set the root of my package structure in the archive?
Thanks for any help.
Phil
Re: root variable path - where has it gone [message #167174 is a reply to message #166989] Mon, 05 July 2004 04:58 Go to previous message
It should now automaticaly detect the root path. If it doesn't, please enter
a bug report with steps to reproduce the problem.
Jerome
"phil meier" <phil.meier@gmx.net> wrote in message
news:cc3pfl$gsm$1@eclipse.org...
archive?
> Phil
Previous Topic:Navigate | Show in
Next Topic:how to configure print?
Current Time: Sun Jul 20 01:59:08 EDT 2025
Powered by FUDForum. Page generated in 0.03483 seconds
