Home » Modeling » EMF » EReference and EKeys
EReference and EKeys [message #1665441] Wed, 11 March 2015 04:21 Go to next message
Dear all,
I can not figure out how the ERefernce works with EKeys. I imagine the EReference should reject to
add an Object if already an Object with the same EKey exists in this particular list. But the
generated default editor is able to set two objects with the same key into a reference.
I am using Ecore Tools with Eclipse 4.4.1.
The object ConductorTypes references ConductorType (without"s" at the end)
The eCore snippet is as below:
<eClassifiers xsi:type="ecore:EClass" name="ConductorType">
<eAnnotations source="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">
<details key="kind" value="elementOnly"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name" eType="ecore:EDataType
http://www.eclipse.org/emf/2003/XMLType#//String"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="material" lowerBound="1"
eType="#//Material" eKeys="#//Material/name">
<details key="kind" value="attribute"/>
<details key="name" value="materialID"/>
</eAnnotations>
</eStructuralFeatures>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="crossSection_mm2" eType="ecore:EDataType
http://www.eclipse.org/emf/2003/XMLType#//Double"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="degreeOfWear_percent"
eType="ecore:EDataType http://www.eclipse.org/emf/2003/XMLType#//Double"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="equivalentRadius_mm"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="temperature_DegreeCentigrade"
defaultValueLiteral="20"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="ConductorTypes">
<eStructuralFeatures xsi:type="ecore:EReference" name="conductorType" lowerBound="1"
upperBound="-1" eType="#//ConductorType" containment="true" eKeys="#//ConductorType/name">
<details key="kind" value="element"/>
<details key="name" value="ConductorType"/>
</eAnnotations>
</eClassifiers>
any help is appreciated, Martin
Re: EReference and EKeys [message #1666053 is a reply to message #1665441] Wed, 11 March 2015 10:19 Go to previous messageGo to next message
Martin,
Comments below.
On 11/03/2015 9:21 AM, Martin Jacob wrote:
> Dear all,
> EReference should reject to add an Object if already an Object with
No, it's a constraint that's validated. If you've enabled live
validation for the generated editor you'll see that it's checked after
the fact...
> But the generated default editor is able to set two objects with the
Imagine changing the value of the key after the fact such that a
duplicate arises as a result of that, rather than as a result of adding
an object to the reference's list.
> end)
> <eAnnotations
> </eAnnotations>
> lowerBound="1"
> <eAnnotations
> </eAnnotations>
> name="degreeOfWear_percent" eType="ecore:EDataType
> name="equivalentRadius_mm" eType="ecore:EDataType
> </eClassifiers>
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
Re: EReference and EKeys [message #1667734 is a reply to message #1666053] Thu, 12 March 2015 02:57 Go to previous messageGo to next message
<html>
<head>
<meta content="text/html; charset=utf-8" http-equiv="Content-Type">
</head>
<font face="Helvetica, Arial, sans-serif">Hi Ed,<br>
<br>
thanks for your comments. Live validation is enabled in preference
setting "Model Validation/Constraints". Do I have to sent an
option / annotation to enable validation? See my settings in the
picture below.<br>
<br>
But still its possible to have twice the same key. In my case the
key is a java.lang.String. May be it has some thing to do with the
use of == instead of equals to compare the keys?<br>
<br>
</font><br>
<img src="https://www.eclipse.org/forums/index.php?t=getfile&amp;id=21144" alt=""><br>
<div class="moz-cite-prefix">Ed Merks schrieb am 11.03.2015 um
15:19:<br>
</div>
<blockquote cite="mid:mdpith$cov$1@xxxxxxxxe.org" type="cite">Martin,
<br>
<br>
Comments below.
<br>
<br>
<br>
<blockquote type="cite">Dear all,
<br>
<br>
imagine the EReference should reject to add an Object if already
<br>
</blockquote>
after the fact...
<br>
<blockquote type="cite">But the generated default editor is able
<br>
</blockquote>
adding an object to the reference's list.
<br>
<br>
<br>
<br>
at the end)
<br>
<br>
<br>
  &lt;eClassifiers xsi:type="ecore:EClass"
name="ConductorType"&gt;
<br>
    &lt;eAnnotations
source=<a class="moz-txt-link-rfc2396E" href="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">"http:///org/eclipse/emf/ecore/util/ExtendedMetaData"</a>&gt;
<br>
      &lt;details key="kind" value="elementOnly"/&gt;
<br>
    &lt;/eAnnotations&gt;
<br>
    &lt;eStructuralFeatures xsi:type="ecore:EAttribute"
<a class="moz-txt-link-freetext" href="http://www.eclipse.org/emf/2003/XMLType#//String">http://www.eclipse.org/emf/2003/XMLType#//String</a>"/&gt;
<br>
    &lt;eStructuralFeatures xsi:type="ecore:EReference"
<br>
        eType="#//Material" eKeys="#//Material/name"&gt;
<br>
      &lt;eAnnotations
<br>
        &lt;details key="kind" value="attribute"/&gt;
<br>
        &lt;details key="name" value="materialID"/&gt;
<br>
<br>
    &lt;/eStructuralFeatures&gt;
<br>
<a class="moz-txt-link-freetext" href="http://www.eclipse.org/emf/2003/XMLType#//Double">http://www.eclipse.org/emf/2003/XMLType#//Double</a>"/&gt;
<br>
<br>
<br>
<br>
defaultValueLiteral="20"/&gt;
<br>
  &lt;/eClassifiers&gt;
<br>
<br>
<br>
name="ConductorTypes"&gt;
<br>
<br>
containment="true" eKeys="#//ConductorType/name"&gt;
<br>
      &lt;eAnnotations
<br>
        &lt;details key="kind" value="element"/&gt;
<br>
        &lt;details key="name" value="ConductorType"/&gt;
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
<br>
</blockquote>
<br>
</body>
</html>
  • Attachment: jibhhegc.png
    (Size: 125.04KB, Downloaded 154 times)
Re: EReference and EKeys [message #1668744 is a reply to message #1667734] Thu, 12 March 2015 12:22 Go to previous message
Martin,
Yes, it's a GenModel property (Decorator) in the Editor section which
you can set when you open the *.genmodel.
Yes, in general the model can be in an invalid state with respect to
this constraint. The runtime should be using .equals to compare keys.
On 12/03/2015 7:57 AM, Martin Jacob wrote:
> Hi Ed,
> setting "Model Validation/Constraints". Do I have to sent an option /
> annotation to enable validation? See my settings in the picture below.
> But still its possible to have twice the same key. In my case the key
> is a java.lang.String. May be it has some thing to do with the use of
> Ed Merks schrieb am 11.03.2015 um 15:19:
>> Martin,
>> Comments below.
>>> Dear all,
>>> the EReference should reject to add an Object if already an Object
>> after the fact...
>>> the end)
>>> <eAnnotations
>>> </eAnnotations>
>>> lowerBound="1"
>>> <eAnnotations
>>> </eAnnotations>
>>> </eClassifiers>
>>> <eAnnotations
>>> </eAnnotations>
>>> </eClassifiers>
Previous Topic:Texo Example is Missing Files
Next Topic:CDO vs NEO4EMF vd TENEO
Current Time: Sun Jul 20 03:46:43 EDT 2025
Powered by FUDForum. Page generated in 0.03520 seconds
