Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » EMFStore vs. CDO(EMFStore CDO)
EMFStore vs. CDO [message #1668743] Thu, 12 March 2015 12:20 Go to next message
Hi all,
I'm choosing the persistence engine for a project that uses EMF, and I'd like to know if I should use EMFStore or CDO. Consider that in my use case this engine will be heavily used by many concurrent clients, so scalability could be an issue.
I did some test with CDO and the MongoDBStore, because I thought to use the scalability features of this DB, but it seems to me that this project is not longer supported, isn't it?
Thank you very much.
Franco
Re: EMFStore vs. CDO [message #1676101 is a reply to message #1668743] Sun, 15 March 2015 06:23 Go to previous messageGo to next message
Am 13.03.2015 um 06:02 schrieb Franco Lombardo:
> Hi all,
> issue.
CDO is the only scalable model repository I know of.
CDO is an active project with a broad user base. Unfortunately the home page is currently broken by CSS changes but it
will be repaired ASAP.
Cheers
/Eike
http://www.esc-net.de
Re: EMFStore vs. CDO [message #1678800 is a reply to message #1668743] Mon, 16 March 2015 06:45 Go to previous messageGo to next message
Hi Franco,
I think it makes sense to define your requirements more in detail. Examples:
- Number of Users?
- Expected Model Size?
- Online vs. Offline?
- How should conflicts be handled?
- and many more
based on that I would spend some time on an evaluation to make sure you
find the best technology for your use case. Depending on the kind of
application you develop, there is even a third alternative: Git in
combination with EMF Compare.
About the scalability of concurrent Users in EMFStore: As the default
Mode in EMFStore is offline, the server only gets active, once a user
(or a system) triggers a commit or update. Of course it depends on the
total number of users, you want to support, but typically the model size
is a more critical factor. If you need to support very large model
instance (millions of elements), the loading and unloading feature of
CDO can help.
Best regards
Jonas
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
> Hi all,
> Franco
Re: EMFStore vs. CDO [message #1679341 is a reply to message #1676101] Mon, 16 March 2015 11:22 Go to previous messageGo to next message
Eike,
thank you very much for your answer.
I had some doubts just about the MongoDBStore because I didn't see many commits on that "driver", and because the class MongoDBStoreAccessor has some methods throwing
throw new UnsupportedOperationException("Not yet implemented"); // TODO Implement me
By the way, I would like to test CDO with the latest version of MySQL/MariaDB, but I was hitting this bug:
bugs.eclipse.org/bugs/show_bug.cgi?id=439772
Bye
Franco
Re: EMFStore vs. CDO [message #1679456 is a reply to message #1679341] Mon, 16 March 2015 12:22 Go to previous messageGo to next message
Am 16.03.2015 um 16:22 schrieb Franco Lombardo:
> Eike,
Sorry, I forgot that the MongoDBStore is not under active development because the initial sponsor went away from it. I
doubt that it has many users. I've just updated https://wiki.eclipse.org/CDO/MongoDB_Store with some more details about
the implementation and characteristics.
I'd like to "modernize" our Mysql adapter but that must wait until I could merge my current overhaul of the entire CDO
UI ( https://www.youtube.com/watch?v=iU21I4-ZxiQ ) into master...
Cheers
/Eike
Re: EMFStore vs. CDO [message #1679486 is a reply to message #1678800] Mon, 16 March 2015 12:36 Go to previous messageGo to next message
Jonas,
thanks for your answer.
Here are some more data on my use case:
>Number of Users?
Hundreds.
Some thousands of objects
>Online vs. Offline?
Online
Well, I would think with something like a pessimistic lock policy.
I know that it's very difficult to give an answer with this scarce data, but what do you think would be better in this scenario?
Thanks in advance.
Franco
Re: EMFStore vs. CDO [message #1687586 is a reply to message #1679456] Thu, 19 March 2015 14:12 Go to previous messageGo to next message
Hi all,
I proposed a fix for the aforementioned bug:
Bye
Franco
Re: EMFStore vs. CDO [message #1688177 is a reply to message #1679486] Fri, 20 March 2015 05:18 Go to previous messageGo to next message
Hi Franco,
based on your requirements to have clients that are permanently
connected to the server (online) and having pessimistic locking I would
recommend you to look at CDO.
Maximilian
Am 16.03.2015 um 17:36 schrieb Franco Lombardo:
> Jonas,
>> Number of Users?
> Hundreds.
>> Online vs. Offline?
> Online
> Thanks in advance.
> Franco
Maximilian Kögel
Re: EMFStore vs. CDO [message #1688396 is a reply to message #1688177] Fri, 20 March 2015 12:02 Go to previous message
Maximilian,
thank you for your answer: I think I'll use CDO.
Bye
Franco
Previous Topic:[Teneo] PSQLException: Too many clients already
Next Topic:[Xcore][CDO] Annotations instead of GenModel
Current Time: Sat Jul 19 23:49:35 EDT 2025
Powered by FUDForum. Page generated in 0.07044 seconds
