Re: Error in generation file .edit et .editor [message #1668755 is a reply to message #1668282] |
Thu, 12 March 2015 12:26   |
Emna,
It doesn't sound like when you created the *.genmodel that you properly
reuse UML2's and Ecore's existing GenPackage but rather are generating
both again into you own plugin. Also, be sure to set the BasePackage of
your own GenPackage so that you get a proper qualified package name,
e.g., org.example...
On 12/03/2015 1:54 PM, Emna Dammak wrote:
> Good morning
> Please I need your help :blush: I created a profile with papyrus then
> I generated the file .ecore and .genmodel
> During generation .edit file and .editor , errors appears in file
> Manifest.mf
> org.eclipse.uml2.uml.presentation does not exist in this plugin
> org.eclipse.uml2.uml.provider does not exist in this plugin
> This is my Manifest file
> Manifest-Version: 1.0
> Bundle-ManifestVersion: 2
> Bundle-Name:% pluginName
> Bundle-SymbolicName: EMFTest.edit; singleton: = true
> Bundle-Version: 1.0.0.qualifier
> Bundle-ClassPath.
> Bundle-Activator: $ profile.provider.ModelEditPlugin Implementation
> Bundle-Vendor:% providerName
> Bundle-Localization: plugin
> Bundle-RequiredExecutionEnvironment: J2SE-1.5
> Export-Package: ecore.provider,
> org.eclipse.uml2.uml.provider,
> profile.provider
> Require-Bundle org.eclipse.core.runtime,
> EMFTest; visibility: = re-export,
> org.eclipse.emf.edit; visibility: = re-export,
> org.eclipse.uml2.common.edit; visibility: = re-export
> Bundle-ActivationPolicy: lazy
> Thank you in advance :)
FUDForum. Page generated in 0.05444 seconds
