ViewerServlet crashes when I deploy a report that uses a library [message #1637699] |
Thu, 26 February 2015 16:18  |
I can build a report that uses a library and successfully display it from Eclipse using Firefox as the browser. However, if I copy the report and library to the deployed birt.war (under Jboss 7) we crash with errors that follow. Here are the details.
- I have deleted both org.apache.xerces and org.apache.xml.serializer from the birt.war.
- Both the library and report reside in the same folder during design.
- The library has nothing other than a defined Data Source and the Master Page set to Landscape.
- The report has a simple text item on the Layout page.
- The report uses the library.
- I drag the library's Data Source onto the report's Layout page.
- I can view the report in Firefox from Eclipse with View report as HTML and it looks correct.
- I copy the library and report filesto the birt.war folder deployed under JBoss.
- I CAN view this from Firefox with a URL like http://IPaddressOfJBoss:JBossPort/RepSys/frameset?__report=TestWithLib.rptdesign.
- Now I return to Dsign and add a Text item to the library's Master Page header, add some text and save the changes.
- In the report I drag the library's Master Page folder onto the report's Layout Page. I now see the text item in the report's header area. I save the report.
- I can still view the report in Firefox from Eclipse with View report as HTML and I see the Library's new Master Page Header.
- I copy the library and report filesto the birt.war folder deployed under JBoss and replace the original files.
- Now when I try to view the report at http://IPaddressOfJBoss:JBossPort/RepSys/frameset?__report=TestWithLib.rptdesign I get the errors that follow.
It seems that adding the Text item to the library's header causes the problem.
Can anyone read this stack and determine what's wrong here?
18:34:24,232 ERROR [org.apache.catalina.core.ContainerBase.[jboss.web].[default-host].[/RepSys].[ViewerServlet]] (http--0.0.0.0-28887-21) Servlet.service() for servlet ViewerServlet threw exception: java.lang.AssertionError
at org.eclipse.birt.report.model.parser.OverriddenValuesState.<init>(OverriddenValuesState.java:64) [org.eclipse.birt.runtime_4.4.1.v20140916-1320.jar:]
at org.eclipse.birt.report.model.parser.ReportElementState.startElement(ReportElementState.java:788) [org.eclipse.birt.runtime_4.4.1.v20140916-1320.jar:]
at org.eclipse.birt.report.model.parser.SimpleMasterPageState.startElement(SimpleMasterPageState.java:69) [org.eclipse.birt.runtime_4.4.1.v20140916-1320.jar:]
at org.eclipse.birt.report.model.parser.ModuleParserHandler.startElement(ModuleParserHandler.java:260) [org.eclipse.birt.runtime_4.4.1.v20140916-1320.jar:]
at org.apache.xerces.parsers.AbstractSAXParser.startElement(AbstractSAXParser.java:496)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanStartElement(XMLDocumentFragmentScannerImpl.java:827)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$FragmentContentDispatcher.dispatch(XMLDocumentFragmentScannerImpl.java:1653)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:324)
at org.apache.xerces.parsers.XML11Configuration.parse(XML11Configuration.java:845)
at org.apache.xerces.parsers.XML11Configuration.parse(XML11Configuration.java:768)
at org.apache.xerces.parsers.XMLParser.parse(XMLParser.java:108)
at org.apache.xerces.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1196)
at org.apache.xerces.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:555)
at org.apache.xerces.jaxp.SAXParserImpl.parse(SAXParserImpl.java:289)
at org.eclipse.birt.report.model.parser.ModuleReader.readModule(ModuleReader.java:98) [org.eclipse.birt.runtime_4.4.1.v20140916-1320.jar:]
at org.eclipse.birt.report.model.parser.DesignReader.read(DesignReader.java:88) [org.eclipse.birt.runtime_4.4.1.v20140916-1320.jar:]
at org.eclipse.birt.report.model.core.DesignSessionImpl.openDesign(DesignSessionImpl.java:309) [org.eclipse.birt.runtime_4.4.1.v20140916-1320.jar:]
at org.eclipse.birt.report.model.api.SessionHandleImpl.openDesign(SessionHandleImpl.java:294) [org.eclipse.birt.runtime_4.4.1.v20140916-1320.jar:]
at org.eclipse.birt.report.model.api.SessionHandle.openDesign(SessionHandle.java:1) [org.eclipse.birt.runtime_4.4.1.v20140916-1320.jar:]
at org.eclipse.birt.report.engine.parser.ReportParser.getDesignHandle(ReportParser.java:158) [org.eclipse.birt.runtime_4.4.1.v20140916-1320.jar:]
at org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.getReportDesignHandle(ReportEngineHelper.java:255) [org.eclipse.birt.runtime_4.4.1.v20140916-1320.jar:]
at org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.openReportDesign(ReportEngineHelper.java:274) [org.eclipse.birt.runtime_4.4.1.v20140916-1320.jar:]
at org.eclipse.birt.report.engine.api.impl.ReportEngine.openReportDesign(ReportEngine.java:616) [org.eclipse.birt.runtime_4.4.1.v20140916-1320.jar:]
at org.eclipse.birt.report.service.ReportEngineService.openReportDesign(ReportEngineService.java:395) [viewservlets.jar:]
at org.eclipse.birt.report.utility.BirtUtility.getRunnableFromDesignFile(BirtUtility.java:608) [viewservlets.jar:]
at org.eclipse.birt.report.context.ViewerAttributeBean.getDesignHandle(ViewerAttributeBean.java:644) [viewservlets.jar:]
at org.eclipse.birt.report.context.ViewerAttributeBean.__init(ViewerAttributeBean.java:224) [viewservlets.jar:]
at org.eclipse.birt.report.context.BaseAttributeBean.init(BaseAttributeBean.java:230) [viewservlets.jar:]
at org.eclipse.birt.report.context.ViewerAttributeBean.<init>(ViewerAttributeBean.java:118) [viewservlets.jar:]
at org.eclipse.birt.report.context.BirtContext.__init(BirtContext.java:44) [viewservlets.jar:]
at org.eclipse.birt.report.context.BaseContext.<init>(BaseContext.java:69) [viewservlets.jar:]
at org.eclipse.birt.report.context.BirtContext.<init>(BirtContext.java:30) [viewservlets.jar:]
at org.eclipse.birt.report.servlet.ViewerServlet.__getContext(ViewerServlet.java:150) [viewservlets.jar:]
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.doGet(BirtSoapMessageDispatcherServlet.java:151) [viewservlets.jar:]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:734) [jboss-servlet-api_3.0_spec-1.0.0.Final.jar:1.0.0.Final]
at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327) [axis.jar:]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:847) [jboss-servlet-api_3.0_spec-1.0.0.Final.jar:1.0.0.Final]
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.service(BirtSoapMessageDispatcherServlet.java:122) [viewservlets.jar:]
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:329) [jbossweb-7.0.13.Final.jar:]
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:248) [jbossweb-7.0.13.Final.jar:]
at org.eclipse.birt.report.filter.ViewerFilter.doFilter(ViewerFilter.java:68) [viewservlets.jar:]
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:280) [jbossweb-7.0.13.Final.jar:]
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:275) [jbossweb-7.0.13.Final.jar:]
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:161) [jbossweb-7.0.13.Final.jar:]
at org.jboss.as.web.security.SecurityContextAssociationValve.invoke(SecurityContextAssociationValve.java:153) [jboss-as-web-7.1.1.Final.jar:7.1.1.Final]
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:155) [jbossweb-7.0.13.Final.jar:]
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102) [jbossweb-7.0.13.Final.jar:]
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109) [jbossweb-7.0.13.Final.jar:]
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:368) [jbossweb-7.0.13.Final.jar:]
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:877) [jbossweb-7.0.13.Final.jar:]
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:671) [jbossweb-7.0.13.Final.jar:]
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:930) [jbossweb-7.0.13.Final.jar:]
at java.lang.Thread.run(Thread.java:722) [rt.jar:1.7.0_11]
Thank you for the help.
FUDForum. Page generated in 0.02983 seconds
