Home » Eclipse Projects » Oomph » [Solved] How to disable an annotation
[Solved] How to disable an annotation [message #1654677] Fri, 06 March 2015 15:06 Go to next message
Is there a way to disable the annotation http://www.eclipse.org/oomph/setup/Enablement, in order that I have total control on my P2 repositories from within the .setup file?
In relation with this question, is there a plan to reinstate RedirectionTask?
[Updated on: Thu, 21 May 2015 11:44] by Moderator
Re: How to disable an annotation [message #1655615 is a reply to message #1654677] Sat, 07 March 2015 00:44 Go to previous messageGo to next message
Julian,
No. If there are alternative p2 locations from which you want to
install the task implementations you could use redirection tasks to
redirect what the annotation specifies to where your alternative is
located.
Re: How to disable an annotation [message #1661121 is a reply to message #1655615] Mon, 09 March 2015 09:41 Go to previous messageGo to next message
Hi Ed,
I would like to use the RedirectionTask, except that currently it has been cancelled! It looks like this:
public boolean isNeeded(SetupTaskContext context) throws Exception
return false;
public void perform(SetupTaskContext context) throws Exception
throw new UnsupportedOperationException("Redirection task can't be executed");
Which is why I asked if it will be reinstated.
I am aware of the conference, so I understand if I don't get a feedback until after.
Re: How to disable an annotation [message #1661274 is a reply to message #1661121] Mon, 09 March 2015 11:00 Go to previous messageGo to next message
Julian,
Redirection tasks work much like variable tasks, i.e., they affect the
setup context, but otherwise there's nothing to actually perform so
they're never "needed" and cannot be performed in the normal sense.
On 09/03/2015 2:41 PM, Julian Enoch wrote:
> Hi Ed,
> return false;
> executed");
> Thanks
Re: How to disable an annotation [message #1661673 is a reply to message #1661274] Mon, 09 March 2015 14:46 Go to previous message
I get it now Smile I got confused because RedirectionTask used to have some code in isNeeded().
Previous Topic:Help cloning git repo
Next Topic:[SOLVED] Cannot launch Eclipse, installed by Oomph
Current Time: Sat Jul 19 17:28:28 EDT 2025
Powered by FUDForum. Page generated in 0.03806 seconds
