Home » Archived » BIRT » global variable
global variable [message #163203] Sat, 20 May 2006 10:37 Go to next message
Originally posted by: nieo1977.maktoob.com
HIIIIIIIIIIIIII
can i wrtie a javascript global variable (report level variable)
when , where , and how can i do that .
and can i assign a value to it from data set then use this variable in my
expressions to do some calculation
because in expression builder there is a limitation that i can see only
one data set that i binding it to table or the list
thank
Re: global variable [message #163451 is a reply to message #163203] Mon, 22 May 2006 11:53 Go to previous messageGo to next message
You should be able to just create a variable in the initialize method:
myvar and dont use the var keyword. Then in the onFetch of your data set
set the variable.
You should be able to reference the variable in your expressions on the
table. BIRT 2.1 offers the
combined Data Sets that may help in this situation though. Create the the
two data sets and then create a joined data set that
does a join between the two.
Jason
"nieo1977" <nieo1977@maktoob.com> wrote in message
news:fb05ee3429d11f5b3d31efdce13c84e6$1@www.eclipse.org...
> HIIIIIIIIIIIIII
> expressions to do some calculation because in expression builder there is
> a limitation that i can see only one data set that i binding it to table
> or the list
> thank
Re: global variable [message #166085 is a reply to message #163451] Wed, 31 May 2006 10:58 Go to previous messageGo to next message
dear Jason
how can i create joined data set that
does a join between the two separate data set???
my birt copy is
Eclipse SDK
Version: 3.1.0
Build id: I20050627-1435
> set the variable.
> Jason
Re: global variable [message #166593 is a reply to message #166085] Thu, 01 June 2006 11:34 Go to previous message
Take a look at this post.
http://birtworld.blogspot.com/2006/05/joined-data-sets-with- birt-21.html
Jason
news:00960c173ec6d078670f646ace4e4d92$1@www.eclipse.org...
> dear Jason
> my birt copy is Eclipse SDK
> Version: 3.1.0
>> set the variable.
>> the two data sets and then create a joined data set that
>> Jason
Previous Topic:Problem building 2.1 R3
Next Topic:Progress Bar
Current Time: Sat Jul 19 08:26:25 EDT 2025
Powered by FUDForum. Page generated in 0.06968 seconds
