Home » Eclipse Projects » GEF » Dragging from the Palette does not have the source feedback
Dragging from the Palette does not have the source feedback [message #165183] |
Fri, 21 January 2005 19:12  |
Originally posted by: kevinlouisnospam.hotmail.com
I am wondering why dragging from the Palette does not show the source
feedback. When I drag a LED from the Palette in the logic sample, I expect
it shows the LED tracking image. However, when I move a LED on the editor,
it shows the tracking image.
I check the codes, the DragEditPartsTracker has the showSourceFeedback
function to show the feedback of all editParts dragged.
But for dragging from the Palette, the CreationTool has the handleMove
function to handle the moust move. It does not have the showSourceFeedback.
To provide the source feedback from the Palette, I have to override the
CombinedTemplaeCreationEntry to create my own CreationTool derived class.
Inside the MyCreationTool class, I override the handleMove and call my own
showSourceFeedback. I need to override some event handler to deactivate the
figure, just like what the DragEditPartsTracker does.
Is it the right way to do it? It is good if the next version of the GEF can
provide this feedback.
Thanks.
Re: Dragging from the Palette does not have the source feedback [message #165803 is a reply to message #165183] |
Wed, 26 January 2005 19:34   |
Dragging from the palette uses native drag and drop, so the
DragEditPartsTracker doesn't even come into the picture. Nor is the
sourceFeedback shown at this time because there is no source (the LED
editpart hasn't been created yet, so you can't ask it to show source
feedback).
Showing the feedback in CreationTool#handleMove will only work if you use
click-and-drop. It won't work for drag-and-drop. Also, on whom are you
invoking showSourceFeedback()?
One hack is to just show the source feedback as the target feedback. That
means that your container(s) would be responsible for showing this feedback
in their showTargetFeedback() for creation requests. Then you won't have to
mess with native DND or with the CreationTool.
"Kevin" <kevinlouisnospam@hotmail.com> wrote in message
news:css5qa$ato$1@www.eclipse.org...
expect
editor,
showSourceFeedback.
the
can
> Thanks.
Re: Dragging from the Palette does not have the source feedback [message #165834 is a reply to message #165803] |
Wed, 26 January 2005 20:59   |
MyCreationTool has a feeback IFigure member which is just RectangleFigure
that tells the user the side of the editPart that will be dropped. Once
this MyCreationTool is deactivated, this feedback is cleaned up.
If I show it in the showTargetFeedback, I need to pass the rectangle info to
the target editPart.
You have a good point that it may work in the click-and-drop case only.
Could you tell me what the handler for the drag-and-drop case?
Thanks.
Kevin
"Pratik Shah" <ppshah@us.ibm.com> wrote in message
news:ct9cud$kt7$1@www.eclipse.org...
> feedback).
feedback
to
> expect
> editor,
> showSourceFeedback.
class.
own
> the
> can
> > Thanks.
Re: Dragging from the Palette does not have the source feedback [message #165965 is a reply to message #165834] |
Thu, 27 January 2005 11:18   |
DND and loaded cursor (creation tool) should both appear the same to the
target editpart. They are both creation requests.
news:ct9hu1$5mb$1@www.eclipse.org...
> to
> Thanks.
> Kevin
>> feedback).
>> That
> feedback
> to
>> expect
>> editor,
>> showSourceFeedback.
> class.
> own
>> > deactivate
>> the
>> > GEF
>> can
>> > Thanks.
Re: Dragging from the Palette does not have the source feedback [message #165986 is a reply to message #165834] |
Thu, 27 January 2005 12:24  |
to
It is already being passed to it (via the CreateRequest).
Like I mentioned earlier, it utilizes native DND. For the logic example,
look at LogicTemplateTransferDropTargetListener.
> Thanks.
> Kevin
> > feedback).
use
That
> feedback
have
> to
> > expect
> > editor,
> > showSourceFeedback.
the
> class.
> own
deactivate
> > the
GEF
> > can
> > > Thanks.
Current Time: Sat Jul 19 14:37:40 EDT 2025
Powered by FUDForum. Page generated in 0.03816 seconds
