Home » Language IDEs » C / C++ IDE (CDT) » use Memory View programmatically
use Memory View programmatically [message #165792] Mon, 13 March 2006 10:43 Go to next message
I have a question about how to use the Memory View in Eclipse
programmatically.
I want to read/display memory for a given address using the Memory View.
So far I have been following the advice given in the Bugzilla Bug 87374:
>To programatically open the memory view:
> PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage().showView
>("org.eclipse.debug.ui.MemoryView");
>To add memory blocks to the view, you need to add memory blocks to the
>memory
>block manager:
> DebugPlugin.getDefault().getMemoryBlockManager().addMemoryBl ocks(new
>IMemoryBlock[] {memoryBlocks});
>In addition to persisting the memory blocks, you may also want to persist
>the
>renderings that are opened. You will need to persist the rendering id and
>id
>of the containers in which a rendering is hosted.
>IViewPart part = PlatformUI.getWorkbench().getActiveWorkbenchWindow
>().getActivePage().showView("org.eclipse.debug.ui.memoryview ");
>IMemoryRenderingSite memoryView = (IMemoryRenderingSite)part;
>IMemoryRenderingContainer container =
>memoryView.getContainer("containerId");
>IMemoryRendering[] renderings = container.getRenderings[];
>When restoring the renderings, you will need to create the rendering, and
>add
>the rendering to the appropriate container within the memory view.
>To create a rendering:
>IMemoryRenderingType renderingType = DebugUITools.getMemoryRenderingManager
>().getRenderingType("rendeirng id");
>IMemoryRendering rendering = renderingType.createRendering();
>Then to add the rendering to the Memory View:
>container.addMemoryRendering(rendering);
>Hope this helps...
>Samantha
If my IMemoryBlock implementation is correctly implemented and I have added
it with
DebugPlugin.getDefault().getMemoryBlockManager().addMemoryBl ocks(),
wouldn't that be enough to render it with the default "raw" memory renderer?
I could not get this to work, so I tried adding a memory renderer to a
memory rendering container,
but I can not get hold of a non-null container. What default memory
rendering containers are available?
My code so far looks like this (the container = null):
IWorkbenchPage page =
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage();
if (page != null)
try
IViewPart view =
page.showView("org.eclipse.debug.ui.MemoryView");
IMemoryRenderingSite memoryView = (IMemoryRenderingSite) view;
MemoryBlockExtentsion mbe = new MemoryBlockExtentsion(new
DummyDebugTarget(), 0);
addMemoryBlocks(new IMemoryBlock[] {mbe});
DebugUITools.getMemoryRenderingManager().
getRenderingType("org.eclipse.debug.ui.rendering.raw_memory ");
IMemoryRenderingContainer container = memoryView.getContainer(
DebugUIPlugin.getUniqueIdentifier() +
".MemoryView.RenderingViewPane.1");
container.addMemoryRendering(rendering); // <-------------
null!!!
catch ...
In summary, what are the minimal steps required in order to display a block
of memory in the Memory View?
- Elin Karasalo
Re: use Memory View programmatically [message #165801 is a reply to message #165792] Mon, 13 March 2006 11:10 Go to previous message
Originally posted by: mikhailk.qnx.com
Try to post this message to the eclipse-debug-dev@eclipse.org mailing list.
"Elin Karasalo" <elka@enea.se> wrote in message
news:dv4434$d9p$1@utils.eclipse.org...
> Hello,
> programmatically.
>>memory
>>block manager:
>>the
>>id
>>add
>>Hope this helps...
>>Samantha
> added it with
> renderer?
> if (page != null)
> try
> IViewPart view =
> null!!!
> catch ...
> block of memory in the Memory View?
> - Elin Karasalo
Previous Topic:what is wrong when debugging
Next Topic:CDT error parser doesnŽt understand wrapped messages
Current Time: Sun Jul 20 09:52:10 EDT 2025
Powered by FUDForum. Page generated in 0.05362 seconds
