Home » Modeling » GMF (Graphical Modeling Framework) » EReference on the diagram
EReference on the diagram [message #165545] Sun, 16 December 2007 07:51 Go to next message
Originally posted by: nospam.nospam.com
I have an EReference in one of my EClasses in the domain model file. In
the generated diagram editor it works as a drop down list in the
Properties view where I can select what I want the EReference to point to.
So I'm not using the EReference as Containment or as a Connection end.
Is there a way within GMF to display the selected EReference from the drop
down list in Properties on a diagram element (as a label)?
Re: EReference on the diagram [message #165631 is a reply to message #165545] Mon, 17 December 2007 07:37 Go to previous messageGo to next message
I found a related request:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=138179
http://dev.eclipse.org/newslists/news.eclipse.modeling.gmf/m sg02396.html
Is there any workaround for this yet?
Re: EReference on the diagram [message #165637 is a reply to message #165631] Mon, 17 December 2007 08:33 Go to previous messageGo to next message
Hello W.F.,
Manually written parser.
Alex Shatalin
Re: EReference on the diagram [message #165735 is a reply to message #165637] Tue, 18 December 2007 05:20 Go to previous messageGo to next message
How about creating a normal String Feature Attribute and mapping it onto a
Feature Label and at the same time assigning the String value of the
EReference to the String EAttribute? That would be two fields in the
Properties view.
There are some Properites in GMF itself that have two fileds for one
property: one drop down list and one uneditable both showing the same
selection.
Can I have some tips how to create that in code?
Re: EReference on the diagram [message #165740 is a reply to message #165735] Tue, 18 December 2007 07:32 Go to previous message
Hello W.F.,
Sure, if you can modify metamodel then the best way is to create transient
derived volatile attribute and implement corresponding method menually.
> of the EReference to the String EAttribute? That would be two fields
> in the Properties view.
AFAIK you can filter out this attribute from properties view - see EMF docs.
> selection.
probably this should be corrected. ;-)
Alex Shatalin
Previous Topic:Compartment
Next Topic:SVG connection rendering
Current Time: Sun Jul 20 04:33:00 EDT 2025
Powered by FUDForum. Page generated in 0.33135 seconds
