Home » Language IDEs » Java Development Tools (JDT) » RC3 and JDK_1_5 CVS branch
RC3 and JDK_1_5 CVS branch [message #165281] Mon, 21 June 2004 08:41 Go to next message
Originally posted by: igorf.ca.ibm.com
Does anyone have problems getting JDK_1_5 branch from CVS using RC3? For
some reason RC3 does not "see" JDK_1_5 tag for most (or all?) of the
files in org.eclipse.jdt.core. Command line cvs seems to be fine.
Igor Fedorenko
Re: RC3 and JDK_1_5 CVS branch [message #165298 is a reply to message #165281] Mon, 21 June 2004 10:01 Go to previous messageGo to next message
I can see it, after forcing to refresh branches.
"Igor Fedorenko" <igorf@ca.ibm.com> wrote in message
news:cb6l10$2ek$1@eclipse.org...
> Regards,
> Igor Fedorenko
Re: RC3 and JDK_1_5 CVS branch [message #165314 is a reply to message #165298] Mon, 21 June 2004 10:19 Go to previous messageGo to next message
Nope, that did not help. The only file that has JDK_1_5 is .project. Can
you check for example branches for build.properties? The real problem
is, when I checkout sources of JDK_1_5 branch I get a lot of java
sources from the HEAD. I'll rollback to RC2 to see if it helps.
>>Hi,
>>Regards,
>>Igor Fedorenko
Re: RC3 and JDK_1_5 CVS branch [message #165322 is a reply to message #165314] Mon, 21 June 2004 10:36 Go to previous messageGo to next message
Never mind, deleted local copy of org.eclipse.jdt.core, got new one from
CVS and everything is ok now. Sorry for the noise.
>>> Hi,
>>> Regards,
>>> Igor Fedorenko
Re: RC3 and JDK_1_5 CVS branch [message #165812 is a reply to message #165322] Thu, 24 June 2004 21:00 Go to previous messageGo to next message
By the way, is it only me having problems with
/org.eclipse.jdt.core/search/org/eclipse/jdt/internal/core/s earch/indexing/IndexManager.java
in JDK_1_5 branch in org.eclipse.jdt.core module?
The field containerPath is defined in an inherited type and an enclosing
scope
org.eclipse.jdt.core/search/org/eclipse/jdt/internal/core/se arch/indexing
/IndexManager.java line 574
regards,
Eugene
>> Can you check for example branches for build.properties? The real
>> problem is, when I checkout sources of JDK_1_5 branch I get a lot of
>> java sources from the HEAD. I'll rollback to RC2 to see if it helps.
>>>> Hi,
>>>> For
>>>> Regards,
>>>> Igor Fedorenko
Re: RC3 and JDK_1_5 CVS branch [message #165849 is a reply to message #165812] Fri, 25 June 2004 06:08 Go to previous message
Everything compiles fine here. Did you check that all your sources
actually come from JDK_1_5 branch?
Igor Fedorenko
> scope
> regards,
> Eugene
>> from CVS and everything is ok now. Sorry for the noise.
>>>>> Hi,
>>>>> RC3? For
>>>>> Regards,
>>>>> Igor Fedorenko
Previous Topic:Parsing XML with SAX using Eclipse
Next Topic:Automatic Java Source Backup (By File Creation)
Current Time: Sat Jul 19 11:57:46 EDT 2025
Powered by FUDForum. Page generated in 0.30225 seconds
