Home » Language IDEs » C / C++ IDE (CDT) » Eclipse, Qt Widgets & gdb possible?(can Eclipse use gdb to debug a project employing Qt Widgets?)
Eclipse, Qt Widgets & gdb possible? [message #1646885] Tue, 03 March 2015 01:35 Go to next message
I've got a project with about 40 classes employing Qt Widgets.
After much pain I've got the makefile to make it, now I'd like to use the MinGW gdb to debug it.
I've managed to get the following simple cpp file to compile and run with gdb :
For this I had to remove this option from the link command : -Wl,s
// Simp1.cpp
int main(int argc, char *argv[]) {
    int k = 0;    //<-----breakpoint
    return 0;
however when I add Qt classes to the mix it does not stop at the breakpoint.
Adding and removing -Wl,s to the link command has no effect.
Using the exact same compile commands and link commands as the QtCreator has no effect.
// Simp2.cpp
#include <QApplication>
#include "MyMainWindow.h"
    QApplication a(argc, argv);
    MyMainWindow mw;
    mw.show();
    return a.exec();
Question : is it at all possible to use MinGW gdb on a Qt class project in Eclipse?
yes or no?
[Updated on: Tue, 03 March 2015 01:37] by Moderator
Re: Eclipse, Qt Widgets & gdb possible? [message #1658223 is a reply to message #1646885] Sun, 08 March 2015 04:26 Go to previous message
Solution found : use CodeBlocks
Previous Topic:Eclipse CDT - external libraries
Next Topic:Eclipse Luna C++ compiles but will not run on OS X 10.8.5
Current Time: Sat Jul 19 05:52:16 EDT 2025
Powered by FUDForum. Page generated in 0.46295 seconds
